Import Podcast Feed OPML not working
Hi. I am unable to import any podcasts from the PlayerFM app. I tried the OPML a few times. Do I need to upload the OPML for reference (not sure how to do that) ?
I am running into the same issue, I’ve attempted loading via mobile app and directly on my server, it doesn’t seem to parse either way.
I’ve been attempting to import my opml from pocket Casts. What system are you trying from?
Same result here, with OPML file exported from the Pocket Casts app on Android.
Same!
Same issue here. Any suggestion yet?
I also have this problem. Tried via mobile Android app and the Desktop Mac client. I keep getting an error “Something went wrong. Make sure the URL is correct and try again.”
Same problem here trying to import a OPML from castbox in plex web.
Unable to import OPML from gPodder. The error reads:
Is there a workaround?
Same issue here. I’ve tried exporting from Overcast and Pocket Casts, both result in same error when trying to import.
Same issue here. Have attempted OPML import on two phones, from PocketCasts.
Every time: “Something went wrong uploading the OPML file. Try again later.”
How can we best escalate this for an immediate fix?
Trying again, from desktop:
THERE IS PRESENTLY NO WAY TO IMPORT OPML TO PLEX
Can confirm that I’m unable to import an OPML file, the import dialog hangs.
Issue is still present. Unable to import on desktop (Mac/Safari) or mobile (android).
Same here for me.
I export OPML from iPhone Overcast to iPhone Files iCloud Drive
Then trying import in Plex app
“Error ettempting to import this OPML file. Please try again later”
Having the same problems importing OPML file that was exported from Pocketcasts. Have tried importing from Plex (Android) and Plex (Windows) - the latter gives the following error message: Something went wrong. Make sure the URL is correct and try again
same error here. on IOS and the web app :frowning:
Any news on this issue?
The issue seems to be fixed in the server. Can anyone else confirm this on with their servers or other device applications?
