Inquiry about Trakt Premium for Plex Scrobble Feature
Inquire about the functionality of Trakt Premium for Plex scrobble integration.
Specifically, I am interested in understanding the capabilities of this integration, and whether it allows for the following:
  1. Syncing Collected Media:
    • Will the premium Trakt subscription enable me to synchronize all my collected movies and TV shows within Plex with Trakt? This includes not only the titles themselves but also their respective ratings.
  2. Discovery Feature Sync:
    • Does the integration extend to content that I have marked and rated using Plex’s discovery feature, even if I haven’t physically collected them within Plex?
  3. Two-way Sync:
    • Is the synchronization process between Trakt and Plex a two-way process, ensuring that updates made on either platform are reflected on the other?
Additionally, I am interested in the following capabilities:
  1. Watchlist Sync:
    • Can I sync my watchlist from Plex to Trakt using the Trakt Premium subscription?
  2. Streaming Client Integration:
    • Will movies and TV shows watched via streaming clients like Netflix, if marked as watched and rated within Plex, also sync with Trakt?
If there are any limitations or specific conditions regarding these features, I would greatly appreciate it if you could provide me with details. This information will be instrumental in helping me make an informed decision about upgrading to Trakt Premium for Plex scrobble.
Would like to know the same thing
There is a work around to this, if you know python a bit.
there used to be good plex integration, however, since they stopped doing plugins, this doesn’t appear to be an option anymore. The most you can do I think, is to scrobble.
There is, at most, this: https://plaxt.astandke.com/
Works perfectly for my needs
Thank you
Actually, the trakt plugin still works, just not on osx. Linux one works fine. There’s a also the GitHub - Taxel/PlexTraktSync: A python script that syncs the movies, shows and ratings between trakt and Plex (without needing a PlexPass or Trakt VIP subscription) project
I was using plextraktsync but it merges my music videos library with the movies library. My music videos have very little metadata and can’t be scraped so the movies library ends up being a mess. (This was under kodi)
I haven’t needed a trakt vip membership to do the webhook as above. It scrobbles my movies and tv shows
