Install Plexamp - nothing but node errors - help!
So I am getting the above error when trying to launch Plexamp, I have uninstalled re-installed and even start fresh with new image and still have gotten no where. I followed everything I could possibly do from the web but still can not get node plexamp/js/index.js to run.
Node is at ver 23.10.0
Has anyone gotten this resolved when this happens?
Thanks.
Try with the most recent Node.js version 20 release. I think 23 might be too recent.
Well that did it. I revert to ver 20.x of NodeJS.
Seems I owe you a bit of gratitude! Thank you!
You’re welcome, glad you got it working!
Since this thread may help someone else.
I added a hat to my Pi4 - a HifiBerry Dac Plus board and it sounds amazing.
You need to add this to the boot config dtoverlay=hifiberry-dacplus, slave
That is not document correctly and is only on their spec sheet that comes with the board. Hope this helps someone.
