Just tested my addsite bag.plist it works
here is Itunes festival also looks like free hd concerts:
https://appletv.itunesfestival.com/v1/2013/bag.plist
Nice
all work
I have question, we are making app for streaming live tv and some channels are 4:3, dose anyone know what tag we need to use for 4:3 streams to show like 16:9?
Does anyone have the bag.plist for WatchESPN or the correct link?
Awesome work being done on this post, BTW
WatchESPN -Â http://espn.go.com/watchespn/appletv/bag.plist
WatchESPN - http://espn.go.com/watchespn/appletv/bag.plist
Tnx for this, do you have maybe sky news and mls?
No I don't. Â Just do some searching on their site and try different variations looking for the right one.
For those of you just tuning in this is a mix of apps I have found and others have posted:
Http://appletv.vevo.com/bag.plist
Http://atv.hbogo.com/bag.plist
Http://atv.qello.com/bag.plist
Http://espn.go.com/watchespn/appletv/bag.plist
Https://crunchyroll.com/appletv/bag.plist
https://watchdisneychannel.go.com/appletv/bag.plist
https://watchdisneyxd.go.com/appletv/bag.plist
https://watchdisneyjunior.go.com/appletv/bag.plist
Lets see what else we can get on this list and from other sources (itunes festival isnt listed but works):
http://support.apple.com/kb/HT4799
Also can someone share how to dump these plists as @japps did?
Maybe with a MITM proxy?
The problem is with HTTPS that is more challenging...
Hi guys, haven't been here for a while. Any progress for none-jailbroken devices? ATV 3? And the links you're posting are apps on ATV 3 that ATV 2 doesn't have, right?
If you didnât add any apps pointed at a local machine during addsite functioning you are out of luck for any atv3 revision until it is jailbroken or someone figures out a way to get addsite back if either ever happen. Post# 237 talks about this and a few posts after that as well. The apps are a mix of apps from ios 5.3 and ios 6 afaik. I belive that the atv2/3 share the same apps/functionality on every ios version so far. Only difference I am aware is listed here such as 1080p, cpu/memory upgrade on the atv3âs:
http://en.wikipedia.org/wiki/Apple_TV
Hey, you have the addsite bag.plist,Â
What about this:
Intercept something other than trailers
Intercept the bag plist
replace the bag plist for that with the addsite one
Effectively turn something else into addsite, kind of like we do with trailers?Â
The addsite bag.plist is used to renable addsite as per post #237. I have added my own app called plexconnect that has a dual function that I call plexconnect on the go since I can bring my atv anywhere inside or outside of my lan and still use plexconnect using a websever and ddns on osx as well as other bag.plists using addsite. This is an alternative to myplex until it is released unless you use the plexconnect.deb (jailbreak requried) from the link below as well post #12. Trailers app functions as it is intended, my ip and dns are both dhcp enabled since I use the plexconnect bag.plist to point to my webserver. I do not use trailers.pem on my atv since everything is ran thru the plexconnect app I have added via addsite. I use untethered ios 5.2 atv2âs only.
http://forums.plexapp.com/index.php/topic/82687-plexconnect-on-the-go-using-ddns-ios-5x-and-jailbreak-required/
My signature has most of the projects I work on as well post #2.
If you didn't add any apps pointed at a local machine during addsite functioning you are out of luck for any atv3 revision until it is jailbroken or someone figures out a way to get addsite back if either ever happen. Post# 237 talks about this and a few posts after that as well. The apps are a mix of apps from ios 5.3 and ios 6 afaik. I belive that the atv2/3 share the same apps/functionality on every ios version so far. Only difference I am aware is listed here such as 1080p, cpu/memory upgrade on the atv3's:
Ok, thank you :)
how do i add addsite.mc on a jailbroken atv?
see link to the blog on first post
I found a all in one decent site for various jailbreaking tools & older ipswâs for the atv2, should help for everyone with saved .shshâs interested in downgrading for addsite functionality, mostly for mac/windows:
http://www.idownloadblog.com/download/
ahh finally got everything setup the way i want. the only problem i have is that setting in plexconnect don't stick. it seems everytime i go back into plexconnect my setting have be reverted back to default.Â
What bag.plist links did you use for ESPN and Vevo?
The link for ESPN we have above has a different icon, ESPN DEV title and doesn't work.
Also the Vevo and Qello links above just stay spinning and never actually open the channel.
BTW, I'm using a jailbroken ATV2 on 5.0.2
He is on ios 5.3 tethered (atv2). I have the same problem with ios 5.2 untethered (atv2) with espn only everything else works.
