iOS client Stops responding.
Morning.
I’ve had repeating problem on the latest client. It totally stops responding to touch. It even the home button.
During playback the iOS client stops responding to touch and home key and will not display on the on screen controls or exit back to iOS.
This happens after a couple of hours solid playback. There are the screen shots from this just happening. As you will see no controls or anything but the playback just confuses until end of the show and then stops.
In order to get control of machine magazine I need to lock the device and unlock it. After that I need to stop plex via the task manager. RestartImg plex means that it works as per normal.
I’ll load the pictures which support this once I’m on wifi.
I’ve suffered this again on my IPAD. I’m also getting on IPad mini which is running an older version of the IOS, (the IPAD is on latest beta)
Anyone looked at this ?
