Hey guys!
First of all, thanks for the great software you gave us, it’s fluid, user friendly, and working amazingly! I have only two problems that I can’t figure on my own…
First one: if I leave open my Ipazzport Mini Keyboard, after 15 minutes, it shutdown by itself. But it seems to be seen by Rasplex as a loop back all the way to the beginning of the movie… The solution I’ve founded is to close the keyboard… But here’s my second problem:
As soon as I put on the keyboard again(To press pause on the movie for example), it loop back also all the way to the beginning of the movie, and get stuck there(Movie doesn’t restart, seems to try to always restart to the beginning)… When this happen, only thing I can do is press a lot the home button, or the stop button, and after 2 minutes, I’m in the launch menu…
Please note: Navigation in the main menu, and the settings are fluid and without problems…
Things I’ve tried:
-Remove the battery from the keyboard, but as soon it is back in, same problem
-Rebooting the Rasplex (doesn’t solve anything)
-Change the USB port for the Keyboard
Hardware:
-Raspberry Plex 3 , 32gb SDHC Class 10 memory card, Power Supply plugged in the wall (HDMI plugged in the Sound AMP, that goes after to the TV)
-IPazzport mini keyboard
-LG 51’’ 1080P TV
-Denon 5.1 AMP
I can provide a video if needed, thank you for your support!
