Ok - I tried again - and Yes it actually worked in __init__.py - but not in ServiceCode.pys unfortunately. Thx for all the help ;)Setting the "Elevated" flag in the Info.plist, then you don't need to import anything in the __init__.py. "Core" and other protected framework methods should be available. For example, check out how I use it in the Unsupported Appstore code. I'm not sure if it's possible to access them in ServiceCode. By nature, Services are intended to run in an even smaller sandbox than plugin code. I'll see what I can find out.
