help with page login
i wanna add a login pref for the following page to a plugin
http://passthepopcorn.me/login.php
def LoginPTP():<br />
  values = {<br />
     'loginform': '',<br />
     'username' : Prefs.Get("PTPusername"),<br />
     'password' : Prefs.Get("PTPpassword"),}<br />
  x = HTTP.Request('http://passthepopcorn.me/login.php', values)<br />
i can't seem to get it to work. can anyone check the source code (it's really short) and see if my code is right?
thanks!
Hey!
*loginform* is not needed, and you have a comma after *password*.
  values = {<br />
    'password' : Prefs.Get("PTPpassword")<br />
  }<br />
Btw: have a look [here](http://forums.plexapp.com/index.php/topic/18324-updating-plugins-to-v2-framework/) to see what changed in framework v2. It's not really very different, but it's a good idea to start new plugins based on v2 instead of v1 framework.
this is a modificiation of the original transmission plugin. i am trying to add a few lines to be able to search another torrent site (the one i am talking about above).
the def’s i added are SearchPassthePopcorn, PTPTorrent, and LoginPTP. also i added another InputDirectory Item under def searchTorrents.
i’m really stuck because the Log just gives me an “Internal Error” and i have no idea what it is. i was hoping it was the comma after password but no sir, that didn’t make a difference.
hope this’ll get to work.
btw ignore the “for item in” parsing under def PTPTorrent, that’s not done yet, i first want the search results to appear. there must be something wrong that it just displays an error.
(the plugin still keeps working other than that part i wrote).
<br />
from PMS import *<br />
from PMS.Objects import *<br />
from PMS.Shortcuts import *<br />
from texttime		import prettyduration<br />
from textbytes		import prettysize<br />
import urllib,urllib2,base64 #temporarily included until HTTP module allows header access<br />
<br />
####################################################################################################<br />
<br />
PLUGIN_PREFIX = "/video/transmission"<br />
PLUGIN_TITLE = "Transmission"<br />
<br />
NAME = L('Title')<br />
<br />
PTPBASE_URL   = "http://passthepopcorn.me/"<br />
PTPSEARCH_URL = "http://passthepopcorn.me/torrents.php?searchstr=%s"<br />
ART           = 'art-default.jpg'<br />
ICON          = 'icon-default.png'<br />
SETTINGS      = 'settings-hi.png'<br />
PAUSE         = 'pause-hi.png'<br />
RESUME        = 'resume-hi.png'<br />
SEARCH        = 'search-hi.png'<br />
TV        		= 'tv-hi.png'<br />
<br />
# Plugin-specific constants<br />
TRANSMISSION_WAITING      = 1<br />
TRANSMISSION_CHECKING      = 2<br />
TRANSMISSION_DOWNLOADING  = 4<br />
TRANSMISSION_SEEDING      = 8<br />
TRANSMISSION_PAUSED        = 16<br />
<br />
<br />
def Start():<br />
    Plugin.AddPrefixHandler(PLUGIN_PREFIX, MainMenu, PLUGIN_TITLE, ICON, ART)<br />
<br />
    MediaContainer.art = R(ART)<br />
    MediaContainer.title1 = NAME<br />
    DirectoryItem.thumb = R(ICON)<br />
<br />
def CreatePrefs():<br />
    Prefs.Add(id='hostname', type='text', default='127.0.0.1:9091', label='Hostname')<br />
    Prefs.Add(id='username', type='text', default='admin', label='Username')<br />
    Prefs.Add(id='password', type='text', default='', label='Password', option='hidden')<br />
    Prefs.Add(id='PTPusername', type='text', default='', label='PTP Username')<br />
    Prefs.Add(id='PTPpassword', type='text', default='', label='PTP Password', option='hidden')<br />
<br />
def ValidatePrefs():<br />
    u = Prefs.Get('username')<br />
    p = Prefs.Get('password')<br />
    h = Prefs.Get('hostname')<br />
    ## do some checks and return a<br />
    ## message container<br />
    if( h ):<br />
        return MessageContainer(<br />
            "Success",<br />
            "Details have been saved"<br />
        )<br />
    else:<br />
            "Error",<br />
            "You need to provide a hostname"<br />
        )<br />
<br />
### Transmission plugin proper starts here<br />
# Transmission requires username, password and Session ID to perform actions<br />
# We attempt to make a connection with just username & password so we get the 409 Conflict response<br />
# This will contain a header with our Session ID<br />
def GetSession():<br />
  url = "http://%s/transmission/rpc/" % h<br />
  request = { "method" : "session-get" }<br />
  headers = {}<br />
  if( u and p and h):<br />
    headers["Authorization"] = "Basic %s" % (base64.encodestring("%s:%s" % (u, p))[:-1])<br />
    try:<br />
      body = urllib2.urlopen(urllib2.Request(url, JSON.StringFromObject(request), headers)).read()<br />
    except urllib2.HTTPError, e:<br />
      if e.code == 401 or e.code == 403:<br />
        return L('ErrorInvalidUsername'), {}<br />
      # Otherwise, we've probably received a 409 Conflict which contains the session ID<br />
      # Once the HTTP module allows access to returned headers, use these to set global authorization:<br />
      # HTTP.SetPassword(h,u,p)<br />
      # HTTP.SetHeader('X-Transmission-Session-Id', e.hdrs['X-Transmission-Session-Id'])<br />
      return e.hdrs['X-Transmission-Session-Id']<br />
    except:<br />
      return L('ErrorNotRunning'), {}<br />
<br />
# Remote Transmission Call -<br />
# Use the RPC methods of Transmission to perform all out actions<br />
def RTC(method, arguments = {}, headers = {}):<br />
  # Once the HTTP module allows access to returned headers and the HTTP.SetPassword also auths JSON, refactor this<br />
<br />
  session_id = GetSession()<br />
<br />
  request = {<br />
    "method":    method,<br />
    "arguments":  arguments<br />
  }<br />
<br />
  # Setup authentication<br />
  if( u and p ):<br />
<br />
  headers["X-Transmission-Session-Id"] = session_id<br />
<br />
  try:<br />
    return "Error reading response from Transmission", {}<br />
  except urllib2.URLError, e:<br />
    return e.reason[1], {}<br />
<br />
  result = JSON.ObjectFromString(body)<br />
<br />
  if result["result"] == "success":<br />
    result["result"] = None<br />
<br />
  if result["arguments"] == None:<br />
    result["arguments"] = {}<br />
<br />
  return result["result"], result["arguments"]<br />
<br />
def MainMenu():<br />
    dir = MediaContainer(viewGroup="List")<br />
    GetSession()<br />
    dir.Append(Function(DirectoryItem(TorrentList,"Torrents",subtitle=None,summary="View torrent progress and control your downloads.",thumb=R(ICON),art=R(ART))))<br />
    dir.Append(Function(DirectoryItem(SearchTorrents,"Search for a torrent",subtitle=None,summary="Browse the TV shows directory or search for files to download.",thumb=R(SEARCH),art=R(ART))))<br />
    dir.Append(PrefsItem(title="Preferences",subtitle="Set Transmission access details",summary="Make sure Transmission is running and 'Remote access' is enabled then enter the access details here.",thumb=R(SETTINGS)))<br />
    return dir<br />
<br />
def TorrentList(sender):<br />
  error, result  = RTC("torrent-get",<br />
    { "fields": [<br />
      "hashString","name","status",<br />
      "eta","errorString",<br />
      "totalSize","leftUntilDone","sizeWhenDone",<br />
      "peersGettingFromUs",  "peersSendingToUs",  "peersConnected",<br />
      "rateDownload",      "rateUpload",<br />
      "downloadedEver",    "uploadedEver"<br />
    ] }<br />
  )<br />
  if error != None:<br />
    if error != "Connection refused":<br />
          "Transmission unavailable",<br />
          "There was an unknown error."<br />
      )<br />
    else:<br />
          "Please make sure Transmission is running with Remote access enabled.  For more information please see http://wiki.plexapp.com/index.php/Transmission"<br />
      )<br />
  elif result["torrents"] != None:<br />
    dir = MediaContainer()<br />
    progress    = 100;<br />
    for torrent in result["torrents"]:<br />
      summary = ""<br />
<br />
      if torrent["errorString"]:<br />
        summary += "Error: %s
" % (torrent["errorString"])<br />
<br />
      if torrent["leftUntilDone"] > 0 and torrent["status"] != TRANSMISSION_SEEDING:<br />
        # Display progress "12.3 MB of 45.6 GB (0%)"<br />
        progress = ((torrent["sizeWhenDone"] - torrent["leftUntilDone"]) /<br />
              (torrent["sizeWhenDone"] / 100))<br />
<br />
        summary += "%s of %s (%d%%)
" % (<br />
            prettysize(torrent["sizeWhenDone"] - torrent["leftUntilDone"]),<br />
            prettysize(torrent["sizeWhenDone"]), progress<br />
          )<br />
<br />
        # Display an ETA; "3 days remaining"<br />
        if torrent["eta"] > 0 and torrent["status"] != TRANSMISSION_PAUSED:<br />
          summary += prettyduration(torrent["eta"]) + " remaining
"<br />
        else:<br />
          summary += "Remaining time unknown
"<br />
<br />
        if torrent["status"] == TRANSMISSION_DOWNLOADING:<br />
          # Display download status "Downloading from 3 of 6 peers"<br />
          summary += "Downloading from %d of %d peers
" % (<br />
              torrent["peersSendingToUs"],<br />
              torrent["peersConnected"]<br />
            )<br />
<br />
          # Display download and upload rates<br />
          summary += "Downloading at %s/s
Uploading at %s/s
" % (<br />
          prettysize(torrent["rateDownload"]),<br />
          prettysize(torrent["rateUpload"])<br />
            )<br />
        else:<br />
          # Display torrent status<br />
          summary += TorrentStatus(torrent)<br />
      else:<br />
        if torrent["status"] == TRANSMISSION_SEEDING:<br />
          summary += "Complete
"<br />
          progress=100<br />
        # else:<br />
        #   Log("torrent status is: %d" % torrent["status"], True)<br />
<br />
        if torrent["downloadedEver"] == 0:<br />
          torrent["downloadedEver"] = 1<br />
<br />
        summary += "%s, uploaded %s (Ratio %.2f)
" % (<br />
            prettysize(torrent["totalSize"]),<br />
            prettysize(torrent["uploadedEver"]),<br />
            float(torrent["uploadedEver"]) / float(torrent["downloadedEver"])<br />
          )<br />
<br />
          summary += "Seeding to %d of %d peers
" % (<br />
              torrent["peersGettingFromUs"],<br />
            )<br />
          summary += "Uploading at %s/s
" % (<br />
            )<br />
      # This is so that we don't bloat the plugin with 101 images.<br />
      # It might change later if PIL is included into the framework<br />
      nearest = int(round(progress/10)*10)<br />
<br />
      # The summary has been built, add the item:<br />
      dir.Append(<br />
          Function(<br />
              PopupDirectoryItem(<br />
                  TorrentInfo,<br />
                  torrent["name"],<br />
                  summary=summary,<br />
                  thumb=R("%s.png" % nearest)<br />
              ),<br />
              name = torrent["name"],<br />
              status = torrent["status"],<br />
              hash = torrent["hashString"]<br />
              )<br />
          )<br />
<br />
    # Add "Pause all torrents" menu item<br />
    dir.Append(Function(DirectoryItem(PauseTorrent,L('MenuPauseAll'),subtitle=None,summary=None,thumb=R(PAUSE),art=R(ART)), hash='all'))<br />
<br />
    # Add "Resume all torrents" menu item<br />
    dir.Append(Function(DirectoryItem(ResumeTorrent,L('MenuResumeAll'),subtitle=None,summary=None,thumb=R(RESUME),art=R(ART)), hash='all'))<br />
<br />
    return dir<br />
<br />
def TorrentInfo(sender, name, status, hash):<br />
  # Display an action menu for this torrent<br />
  # #######################################<br />
  dir.Append(Function(DirectoryItem(ViewFiles,			L('MenuViewFiles'),	subtitle=None,summary=None,thumb=R(ICON),art=R(ART)), hash=hash))<br />
  if status == TRANSMISSION_PAUSED:<br />
    dir.Append(Function(DirectoryItem(ResumeTorrent,L('MenuResume'),		subtitle=None,summary=None,thumb=R(ICON),art=R(ART)), hash=hash))<br />
  else:<br />
    dir.Append(Function(DirectoryItem(PauseTorrent,	L('MenuPause'),			subtitle=None,summary=None,thumb=R(ICON),art=R(ART)), hash=hash))<br />
  dir.Append(Function(DirectoryItem(RemoveTorrent,	L('MenuRemove'),		subtitle=None,summary=None,thumb=R(ICON),art=R(ART)), hash=hash))<br />
  dir.Append(Function(DirectoryItem(DeleteTorrent,	L('MenuDelete'),		subtitle=None,summary=None,thumb=R(ICON),art=R(ART)), hash=hash))<br />
<br />
  return dir<br />
<br />
def TorrentStatus(torrent):<br />
  if torrent == None or torrent["status"] == None:<br />
    return L('TorrentStatusUnknown')<br />
  elif torrent["status"] == TRANSMISSION_WAITING:<br />
    return L('TorrentStatusWaiting')<br />
  elif torrent["status"] == TRANSMISSION_CHECKING:<br />
    return L('TorrentStatusVerifying')<br />
  elif torrent["status"] == TRANSMISSION_PAUSED:<br />
    return L('TorrentStatusPaused')<br />
  elif torrent["status"] == TRANSMISSION_DOWNLOADING:<br />
    return L('TorrentStatusDownloading')<br />
  elif torrent["status"] == TRANSMISSION_SEEDING:<br />
    return L('TorrentStatusSeeding')<br />
  else:<br />
<br />
def ViewFiles(sender, hash):<br />
  # Display the contents of a torrent<br />
  # #################################<br />
  # Log("Need details for: %s" % hash, True)<br />
<br />
      { "ids": [ hash ], "fields": [ "hashString", "files", "wanted" ] })<br />
<br />
      "Transmission error",<br />
      "Unable to list files."<br />
    )<br />
<br />
    if torrent["hashString"] != hash:<br />
      continue<br />
<br />
    for i in range(0, len(torrent["files"])):<br />
      file = torrent["files"]*<br />
<br />
      Log("Name: %s" % (file["name"]), True)<br />
<br />
      if torrent["wanted"]* == 1:<br />
        if file["bytesCompleted"] == file["length"]:<br />
          summary = "Complete"<br />
        else:<br />
          summary = "%s of %s (%s%%)
" % (<br />
              prettysize(file["bytesCompleted"]),<br />
              prettysize(file["length"]),<br />
              (file["bytesCompleted"]) / (file["length"] / 100)<br />
          )<br />
      else:<br />
        summary = "Not Downloading"<br />
<br />
      dir.Append(PopupDirectoryItem("%d" % i, file["name"], summary=summary))<br />
<br />
    return dir<br />
<br />
<br />
def ResumeTorrent(sender, hash):<br />
  # The following several functions could have<br />
  # been bundled together but I decided to keep them separate<br />
  action = "torrent-start"<br />
  arguments = { "ids" : hash }<br />
  error, result = RTC(action, arguments)<br />
    return MessageContainer("Error", error)<br />
  else:<br />
    return MessageContainer("Transmission", L('ActionTorrentResumed'))<br />
<br />
def PauseTorrent(sender, hash):<br />
  action = "torrent-stop"<br />
  else:<br />
    return MessageContainer("Transmission", L('ActionTorrentPaused'))<br />
<br />
def RemoveTorrent(sender, hash):<br />
  action = "torrent-remove"<br />
  else:<br />
    return MessageContainer("Transmission", L('ActionTorrentRemoved'))<br />
<br />
def DeleteTorrent(sender, hash):<br />
  arguments = { "ids" : hash, "delete-local-data": True}<br />
  else:<br />
    return MessageContainer("Transmission", L('ActionTorrentDeleted'))<br />
<br />
def AddTorrent(sender, torrentUrl):<br />
  action = "torrent-add"<br />
  arguments = { "filename" : torrentUrl}<br />
  Log(torrentUrl, True)<br />
  else:<br />
    return MessageContainer("Transmission", L('ActionTorrentAdded'))<br />
<br />
# These next few extremely handy functions are based on work done in the uTorrent Plugin.<br />
# The first one would list all shows mentioned on http://ezrss.it/shows/<br />
# This is a long list so it isn't used<br />
def TVShowList(sender):<br />
<br />
<br />
    showsPage = XML.ElementFromURL('http://ezrss.it/shows/', isHTML=True, errors='ignore')<br />
<br />
    #Assign to blocks, and remove the first block (A, B, C, etc...)<br />
    blocks = showsPage.xpath('//div[@class="block"]')<br />
    blocks.pop(0)<br />
<br />
    for block in blocks:<br />
        for href in block.xpath('.//a'):<br />
            if href.text != "# Top":<br />
                requestUrl = "http://ezrss.it" + href.get("href") + "&mode=rss"<br />
                dir.Append(Function(DirectoryItem(TVEpisodeList,href.text,subtitle=None,summary=None,thumb=R(ICON),art=R(ART)),name=href.text,url=requestUrl))<br />
<br />
    return dir<br />
<br />
# This grabs a list of all first letters used on that page<br />
def TVShowListFolders(sender):<br />
<br />
<br />
<br />
    blocks.pop(0)<br />
<br />
        letter = block.xpath("h2")[0].text<br />
        dir.Append(Function(DirectoryItem(TVShowListSubfolders,letter,subtitle=None,summary=None,thumb=R(ICON),art=R(ART)),letter=letter))<br />
    return dir<br />
<br />
# This returns only shows within that subsection<br />
def TVShowListSubfolders(sender, letter):<br />
<br />
<br />
<br />
    blocks = showsPage.xpath('//div[@class="block" and h2 = "%s"]' % letter)<br />
<br />
<br />
    return dir<br />
<br />
# This lists all available torrents for the chosen show<br />
def TVEpisodeList(sender, name, url):<br />
<br />
<br />
    feed = XML.ElementFromURL(url, isHTML=False, errors='ignore').xpath("//item")<br />
<br />
    for element in feed:<br />
        title = element.xpath("title")[0].text<br />
        link = element.xpath("link")[0].text<br />
        dir.Append(Function(DirectoryItem(AddTorrent,title,subtitle=None,summary=None,thumb=R(ICON),art=R(ART)),torrentUrl=link))<br />
<br />
    return dir<br />
<br />
# There's a minor bug in the InputDirectoryItem in that it doesn't<br />
# like it when subtitle is passed as a named argument. Just saying.<br />
def SearchTorrents(sender):<br />
  dir.Append(Function(DirectoryItem(			TVShowListFolders,		L('MenuBrowseTV'),		subtitle="Browse the TV shows directory",	summary=None,thumb=R(TV),art=R(ART))))<br />
  dir.Append(Function(InputDirectoryItem(	SearchEZTV,						L('MenuSearchTV'),		"Search the TV shows directory",	summary="This will use EZTV to search.",thumb=R(SEARCH),art=R(ART))))<br />
  dir.Append(Function(DirectoryItem(			SearchIsoHunt,				L('MenuSearchOther'),	subtitle="Search for other torrents",			summary="This will use IsoHunt to search.",thumb=R(SEARCH),art=R(ART))))<br />
  dir.Append(Function(SearchDirectoryItem(	SearchPassthePopcorn,				L('Search PassthePopcorn'),	"Search PassThePopcorn",			summary="This will use PassthePopcorn to search.",thumb=R(SEARCH),art=R(ART))))<br />
  return dir<br />
<br />
# I might drop IsoHunt from the next version as it returns a lot of...ahem...adult results regardless of search terms.<br />
def SearchIsoHunt(sender):<br />
  dir.Append(Function(InputDirectoryItem(SearchIsoHuntCategory,"Search all categories","",summary="",thumb=R(ICON),art=R(ART)),category=99))<br />
  dir.Append(Function(InputDirectoryItem(SearchIsoHuntCategory,"Movies","",summary=None,thumb=R(ICON),art=R(ART)),category=1))<br />
  dir.Append(Function(InputDirectoryItem(SearchIsoHuntCategory,"Audio","",summary=None,thumb=R(ICON),art=R(ART)),category=2))<br />
  dir.Append(Function(InputDirectoryItem(SearchIsoHuntCategory,"TV Shows","",summary=None,thumb=R(ICON),art=R(ART)),category=3))<br />
  dir.Append(Function(InputDirectoryItem(SearchIsoHuntCategory,"Games","",summary=None,thumb=R(ICON),art=R(ART)),category=4))<br />
  dir.Append(Function(InputDirectoryItem(SearchIsoHuntCategory,"Music Video","",summary=None,thumb=R(ICON),art=R(ART)),category=10))<br />
  dir.Append(Function(InputDirectoryItem(SearchIsoHuntCategory,"Applications","",summary=None,thumb=R(ICON),art=R(ART)),category=5))<br />
  dir.Append(Function(InputDirectoryItem(SearchIsoHuntCategory,"Pictures","",summary=None,thumb=R(ICON),art=R(ART)),category=7))<br />
  dir.Append(Function(InputDirectoryItem(SearchIsoHuntCategory,"Comics","",summary=None,thumb=R(ICON),art=R(ART)),category=8))<br />
  dir.Append(Function(InputDirectoryItem(SearchIsoHuntCategory,"Books","",summary=None,thumb=R(ICON),art=R(ART)),category=9))<br />
  dir.Append(Function(InputDirectoryItem(SearchIsoHuntCategory,"Miscellaneous","",summary=None,thumb=R(ICON),art=R(ART)),category=0))<br />
  dir.Append(Function(InputDirectoryItem(SearchIsoHuntCategory,"Unclassified","",summary=None,thumb=R(ICON),art=R(ART)),category=11))<br />
  return dir<br />
<br />
def SearchIsoHuntCategory(sender, query=None, category=99):<br />
  url = "http://isohunt.com/js/rss"<br />
  if query != None:<br />
    url += "/%s" % query<br />
  if category != 99:<br />
    url += "?iht=%d" % category<br />
  Log(url, True)<br />
  if feed == None:<br />
    return MessageContainer("Error", "Search returned no results")<br />
  if len(feed) == 0:<br />
    return MessageContainer("Error", "No results").ToXML()<br />
    category = element.xpath("category")[0].text<br />
    link = element.find("enclosure").get("url")<br />
    size = prettysize(int(element.find("enclosure").get("length")))<br />
    dir.Append(Function(DirectoryItem(AddTorrent,title,subtitle=None,summary="Category: %s
Size: %s" % (category,size),thumb=R(ICON),art=R(ART)),torrentUrl=link))<br />
  return dir<br />
<br />
def SearchPassthePopcorn(sender, query=None):<br />
  LoginPTP()<br />
  Log("Success!")<br />
  pageUrl2 = PTPSEARCH_URL % (String.Quote(query, usePlus=True))<br />
  content1=XML.ElementFromURL(pageUrl2, isHTML=False, errors='ignore')<br />
  for item in content1.xpath('//td[contains(@id,"large_groupid")]'):<br />
    Log(item)<br />
    title = item.xpath('./img')[0].get('title')<br />
    titleUrl = item.xpath('./a')[0].get('href')<br />
    thumb = item.xpath('./img')[0].get('src')<br />
    dir.Append(Function(DirectoryItem(PTPTorrent,title=title, titleUrl=titleUrl)))<br />
  return dir<br />
<br />
def PTPTorrent(sender, titleUrl):<br />
  pageUrl = PTPBASE_URL + titleUrl<br />
  content2=XML.ElementFromURL(pageUrl, isHTML=True, errors='ignore')<br />
  for item in content2.xpath('//td[contains(@id,"large_groupid")]'):<br />
    Log(item)<br />
    dir.Append(Function(DirectoryItem(AddTorrent,title,subtitle=None,thumb=R(ICON),art=R(ART)),torrentUrl=titleUrl))<br />
  return dir<br />
<br />
  values = {<br />
     'password' : Prefs.Get("PTPpassword")}<br />
<br />
# This function was a lot longer in the previous version of the<br />
# Framework. It was so much simpler this time round.<br />
def SearchEZTV(sender, query=None):<br />
  url = "http://ezrss.it/search/index.php?simple&mode=rss&show_name="<br />
    url += "%s" % query<br />
    return MessageContainer("Error", "Search failed")<br />
    return MessageContainer("Error", "No results")<br />
  return dir<br />
<br />
# This is currently unused due to issues between PIL and Framework v1<br />
# re-enable it later if PIL gets included in the framework by sticking this at the top:<br />
# from icon      import TorrentIconCached<br />
# and the rest in a file called icon.py:<br />
# from PMS import *<br />
# from PMS.Objects import *<br />
# from PMS.Shortcuts import *<br />
# from PIL import Image, ImageFont, ImageDraw<br />
# import cStringIO<br />
#<br />
# LargeFont	= ImageFont.truetype("/Library/Fonts/Arial Bold.ttf", 100)<br />
# SmallFont	= ImageFont.truetype("/Library/Fonts/Arial Bold.ttf", 30)<br />
#<br />
# def TorrentIcon(name, status, progress=100):<br />
# 	result	= cStringIO.StringIO()<br />
# 	image	= Image.new("RGBA", (304, 450), (0, 0, 0, 0))<br />
# 	draw	= ImageDraw.Draw(image)<br />
#<br />
#  	Log("name: %s, status: %s" % (name, status), True)<br />
# 	draw.text((1, 1), status, font=LargeFont, fill="black")<br />
# 	draw.text((0, 0),	status,	font=LargeFont, fill="white")<br />
# 	draw.text((1, 131),	name,	font=SmallFont, fill="black")<br />
# 	draw.text((0, 130),	name,	font=SmallFont, fill="white")<br />
#<br />
# 	if progress >= 0:<br />
# 		draw.rectangle( ( 0, 170, 3 * progress, 200 ), fill="white", outline="black")<br />
# 		draw.rectangle( ( 3 * progress,	170, 300, 200 ), fill="#444", outline="black")<br />
#<br />
# 	image.save(result, "PNG")<br />
# 	imagedata=result.getvalue()<br />
# 	return DataObject(data = result.getvalue(), contentType="image/png")<br />
#<br />
# def TorrentIconCached(name, status, progress=100):<br />
# 	# TorrentIconCached(torrent["name"],"%d%%" % progress,progress)<br />
# 	if Data.Exists("%s.png" % progress):<br />
# 		return DataObject(data = Data.Load("%s.png" % progress), contentType="image/png")<br />
# 	else:<br />
# 		return TorrentIcon(name, status, progress)<br />
Assuming your login is working...
isn't this ALWAYS searching for "None"?
  LoginPTP()<br />
well if it was that it would at least give me no results (an empty page). whether i leave it with None or just “query”, the log just gives me “an internal error occured”.
and it doesn’t work.
by the way, the EZTV search further below also has query=none and there the search works fine, so i don’t think it really matters.
how can i be 100% sure the login works? the stupid log gives me NOTHING. just:
2/16/11 6:19:20 PM com.plexapp.mediaserver[166] 18:19:20.934142: com.plexapp.plugins.transmission : (Framework) Handling request : /video/transmission/:/function/SearchPassthePopcorn
2/16/11 6:19:23 PM com.plexapp.mediaserver[166] 18:19:23.087189: com.plexapp.plugins.transmission : (Framework) An internal error occurred
2/16/11 6:19:23 PM com.plexapp.mediaserver[166] 18:19:23.087351: com.plexapp.plugins.transmission : (Framework) Request not handled by plug-in
no matter how many “Log(blablabla)”
I'm not sure, pooloser, just trying to help.
Have you tried "Log(x)" after logging in?
as i said, the log just gives me an internal error… what can i do?
11:15:53 T:2953850880 M:2632134656 ERROR: Process - Invalid content type for http://127.0.0.1:32400/video/transmission/:/function/SearchPassthePopcorn?function_args=Y2VyZWFsMQozCmRpY3QKZGljdApQTVMuT2JqZWN0cy5JdGVtSW5mb1JlY29yZAoxCnIyCnM2CnNlbmRlcjQKczIxClNlYXJjaCBQYXNzdGhlUG9wY29ybnM5Cml0ZW1UaXRsZXMxMgpUcmFuc21pc3Npb25zNgp0aXRsZTFuczYKdGl0bGUyczQ3Ci92aWRlby90cmFuc21pc3Npb24vOi9yZXNvdXJjZXMvYXJ0LWRlZmF1bHQuanBnczMKYXJ0cjEKcjAK&query=blue
11:15:53 T:2953850880 M:2632134656 ERROR: =====================================================================================
11:15:53 T:2696549696 M:2632314880 ERROR: GetDirectory - Error getting http://127.0.0.1:32400/video/transmission/:/function/SearchPassthePopcorn?function_args=Y2VyZWFsMQozCmRpY3QKZGljdApQTVMuT2JqZWN0cy5JdGVtSW5mb1JlY29yZAoxCnIyCnM2CnNlbmRlcjQKczIxClNlYXJjaCBQYXNzdGhlUG9wY29ybnM5Cml0ZW1UaXRsZXMxMgpUcmFuc21pc3Npb25zNgp0aXRsZTFuczYKdGl0bGUyczQ3Ci92aWRlby90cmFuc21pc3Npb24vOi9yZXNvdXJjZXMvYXJ0LWRlZmF1bHQuanBnczMKYXJ0cjEKcjAK&query=blue
11:15:53 T:2696549696 M:2632331264 ERROR: CGUIMediaWindow::GetDirectory(http://127.0.0.1:32400/video/transmission/:/function/SearchPassthePopcorn?function_args=Y2VyZWFsMQozCmRpY3QKZGljdApQTVMuT2JqZWN0cy5JdGVtSW5mb1JlY29yZAoxCnIyCnM2CnNlbmRlcjQKczIxClNlYXJjaCBQYXNzdGhlUG9wY29ybnM5Cml0ZW1UaXRsZXMxMgpUcmFuc21pc3Npb25zNgp0aXRsZTFuczYKdGl0bGUyczQ3Ci92aWRlby90cmFuc21pc3Npb24vOi9yZXNvdXJjZXMvYXJ0LWRlZmF1bHQuanBnczMKYXJ0cjEKcjAK&query=blue) failed
11:15:53 T:2696549696 M:2632155136 NOTICE: Bonjour: Did resolve service - iMac (type: _plexmediasvr._tcp.) - with 2 addresses, resolved=1 and url=http://127.0.0.1:32400
edit. i DID it! :smiley: i am meanwhile posting the thing i’m currently stuck on:
i wanna parse the data from the followign code (it’s a .php page):
	<td class="small" id="large_groupid_35638" rowspan="3"><br />
											<a href="torrents.php?id=35638" onclick="Previewsrc('http://ptpimg.me/od78j2.jpg','Blue Valentine');"><img src="http://ptpimg.me/od78j2.jpg" alt="" title="Blue Valentine" width="117"></a><br />
			<br />
		</td><br />
		<td colspan="2"><br />
			<a href="torrents.php?id=35638" title="View Torrent">Blue Valentine</a> [2010] by <a href="artist.php?id=8955">Derek Cianfrance</a>			<span style="float:right;"><a href="#showimg_35638" id="bookmarklink35638" onclick="Bookmark(35638,'Unbookmark');return false;">Bookmark</a></span><br />
			<br /><br />
			<div class="tags" style="padding:2px"><br />
				<img src="/static/common/imdb/imdb.7.9.png">				<span style="vertical-align: top"><a href="torrents.php?action=basic&amp;taglist=drama">drama</a>, <a href="torrents.php?action=basic&amp;taglist=romance">romance</a></span><br />
							</div><br />
		</td><br />
and my xpath code is this:
  content1=XML.ElementFromURL(pageUrl2, isHTML=True, errors='ignore')<br />
  for item in content1.xpath('//td[contains(@id,"large_groupid_")]'):<br />
    Log(item)<br />
    title = item.xpath('.//img')[0].get('title')<br />
    titleUrl = item.xpath('.//a')[0].get('href')<br />
    img = item.xpath('.//img')[0].get('src')<br />
    dir.Append(Function(DirectoryItem(PTPTorrent, img, title, thumb)))<br />
  return dir<br />
any guidance on this?
