Is there a "Delete" Icon? - How do you delete a show?
Hi everyone,
Kinda new to PHT so I’m probably missing something obvious but I cannot seem to find a “Delete” icon in PHT like I can in the web browser app. I’m using a very rudimentary Windows remote that does not have a “Delete” key although I could probably program one in. But shouldn’t there be a “Trash” can icon somewhere or … dots to bring up a pull down menu with the delete function?
Thanks in advance,
Dean
@drrohle said:
Hi everyone,
Thanks in advance,
Dean
You can delete items with the context menu. Highlight an item and press ‘C’ to bring up the context menu.
What if you don’t have a “C” on your remote?
Should I request a special “feature” that already exists in the web interface?
You’d have to remap the remote keys via remote.xml or keyboard.xml depending on what kind of remote you’re talking about. You can always request a feature change. The team may or may not respond.
Tried it last night and it works just fine using the C key or just the Delete key on the second level of the TV Shows menu. Also reprog’d my remote to have a “Del” key. :-*
Now if I can just keep it from locking up Windows 10 when I try to exit, sleep or shutdown from the main menu I’ be really happy with OpenPlex HT.
