Issue playing a specific song in a sync'd playlist
Latest build (v4.9) issue with sync’d music playlists.
This happened in a previous build so assuming it is a simple issue but I can no longer start playing from a specific song on a sync’d playlist on my iPhone. If I go to playlists, select a list, and then scroll down to start near the bottom or select a specific song a touch doesn’t do anything, I can only use the controls at the top to play, shuffle etc.
