I start up plex media center and plex app.
I open terminal follow all instructions with the newest plex connect master folder, this is what I get, seems like error codes. Is it my router thats causing the problem? Its an airport extreme newest version.
21:09:37 PlexConnect: ***
21:09:37 PlexConnect: PlexConnect
21:09:37 PlexConnect: Press CTRL-C to shut down.
21:09:37 Settings: add section PlexConnect
21:09:37 Settings: add option logpath=.
21:09:37 Settings: add option enable_dnsserver=True
21:09:37 Settings: add option ip_webserver=0.0.0.0
21:09:37 Settings: add option prevent_atv_update=True
21:09:37 Settings: add option port_dnsserver=53
21:09:37 Settings: add option enable_plexconnect_autodetect=True
21:09:37 Settings: add option port_pms=32400
21:09:37 Settings: add option port_webserver=80
21:09:37 Settings: add option ip_plexconnect=0.0.0.0
21:09:37 Settings: add option certfile=./assets/certificates/trailers.pem
21:09:37 Settings: add option ip_dnsmaster=8.8.8.8
21:09:37 Settings: add option loglevel=Normal
21:09:37 Settings: add option ip_pms=192.168.178.10
21:09:37 Settings: add option enable_plexgdm=True
21:09:37 Settings: add option port_ssl=443
21:09:37 PlexConnect: started: 21:09:37
21:09:37 PlexConnect: IP_self: 10.0.0.17
21:09:37 DNSServer: started: 21:09:37
21:09:37 DNSServer: ***
21:09:37 DNSServer: DNSServer: Serving DNS on port 53.
21:09:37 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 10.0.0.17
21:09:37 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
21:09:37 DNSServer: forward other to higher level DNS: 8.8.8.8
21:09:37 WebServer: started: 21:09:37
21:09:37 WebServer: Failed to access certificate: /Users/knapp209/Desktop/PlexConnect-master/./assets/certificates/trailers.pem
21:09:37 WebServer: ***
21:09:37 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
21:09:37 PlexGDM: ***
21:09:37 PlexGDM: looking up Plex Media Server
21:09:37 PlexConnect: WebServer_SSL not alive. Shutting down.
21:09:37 PlexConnect: Shutting down.
21:09:38 PlexGDM: servers discovered: 1
21:09:38 XMLConverter: PlexGDM - PMS: 10.0.0.17:32400
21:09:38 WebServer: Shutting down.
21:09:42 DNSServer: Shutting down.
21:09:42 PlexConnect: shutdown
Mac-Mini-■■■■■■:PlexConnect-master knapp209$
Any input would be helpful...Running on a Mac Mini with 10.8.5
