Issues with command line media scanner, synology NAS
Server Version#: 1.27.1.5916
Player Version#: N/A
Trying to follow the article showing how to use the media scanner from the command line, but I am getting database errors, with and without setting LD_LIBRARY_PATH. Would like to automate refreshing media when new content is added.
stew@synology:~$ export LD_LIBRARY_PATH=/volume1/@appstore/PlexMediaServer
stew@synology:~$ /volume1/@appstore/PlexMediaServer/Plex\ Media\ Scanner -l
libc++abi: terminating with uncaught exception of type soci::soci_error: sqlite3_statement_backend::prepare: no such column: library_sections.content_changed_at for SQL: select library_sections.id as ‘library_sections_id’, library_sections.library_id as ‘library_sections_library_id’, library_sections.name as ‘library_sections_name’, library_sections.name_sort as ‘library_sections_name_sort’, library_sections.section_type as ‘library_sections_section_type’, library_sections.language as ‘library_sections_language’, library_sections.agent as ‘library_sections_agent’, library_sections.scanner as ‘library_sections_scanner’, library_sections.user_thumb_url as ‘library_sections_user_thumb_url’, library_sections.user_art_url as ‘library_sections_user_art_url’, library_sections.user_theme_music_url as ‘library_sections_user_theme_music_url’, library_sections.created_at as ‘library_sections_created_at’, library_sections.updated_at as ‘library_sections_updated_at’, library_sections.scanned_at as ‘library_sections_scanned_at’, library_sections.user_fields as ‘library_sections_user_fields’, library_sections.query_xml as ‘library_sections_query_xml’, library_sections.query_type as ‘library_sections_query_type’, library_sections.uuid as ‘library_sections_uuid’, library_sections.changed_at as ‘library_sections_changed_at’, library_sections.content_changed_at as ‘library_sections_content_changed_at’ from library_sections
****** PLEX MEDIA SCANNER CRASHED, CRASH REPORT WRITTEN: /var/services/homes/stew/Library/Application Support/Plex Media Server/Crash Reports/1.27.1.5916-6b0e31a64/PLEX MEDIA SCANNER/c0be9bbf-80a6-4bb9-f8e85599-91851213.dmp
Error in command line:the argument for option ‘–serverUuid’ should follow immediately after the equal sign
Crash Uploader options (all are required):
–directory arg Directory to scan for crash reports
–serverUuid arg UUID of the server that crashed
–userId arg User that owns this product
–platform arg Platform string
–platformVersion arg Platform version string
–vendor arg Vendor string
–device arg Device string
–model arg Device model string
–sentryUrl arg Sentry URL to upload to
–sentryKey arg Sentry Key for the project
–version arg Version of the product
–allowRetries arg Whether we will allow retries
Aborted (core dumped)
My media server already refreshes media data when new content is added… Check Plex > Settings > Scheduled Tasks.
Scheduled tasks might be configured to refresh metadata – but not to scan a library.
You find those options in Settings > [Server Name] > Library; look for Scan my library automatically (if supported by the host OS) or Scan my library periodically.
