It's normal that the databases folder have duplicated plugins library.db?
i’m watching that my plex are not syncing the item watched for example if a let a series episode in episode 5 when i come back to contionue watching i it show me that im in episode 4 and its wrong, so i enter to the plex database folder and i found duplicated item like this
com.plexapp.plugins.library.blobs.db-2022-12-06
com.plexapp.plugins.library.blobs.db-2022-12-09
com.plexapp.plugins.library.blobs.db-2022-12-12
com.plexapp.plugins.library.blobs.db-2022-12-15
and those too
com.plexapp.plugins.library.db-2022-12-06
com.plexapp.plugins.library.db-2022-12-09
com.plexapp.plugins.library.db-2022-12-12
com.plexapp.plugins.library.db-2022-12-15
maybe there its the error ? or can i do something else fo repair it?
i update the server to 1.30.0.6486 and same issue.
Those are backups of the database created by the scheduled tasks run during server maintenance.
When tinkering with the database, ignore the versions with a date in their file name.
Also make sure to stop the server before messing with the database!
I understand, thanks. so do you have any idea why continuing to watch is not synchronized correctly?
i have activated the Sync Your Watch State and Ratings on plex servers too
and the same issue.
If you mean partially watched items, that information is not synced.
https://support.plex.tv/articles/sync-watch-state-and-ratings/
Tip!: If you stop watching an item part way through, the “in progress” information is not synced. Only if or when you complete the title (so it is “watched”) will the state get synced up. That’s intentional to ensure the source can’t be inferred to be a personal server.
