Is there a way to have the server return a json object vs xml when using the server rest api?
http://localhost:32400/library
i tried to set the Content-Type to application/json on the get request. but no luck.
I don’t thinks so. XML is pretty much it. Why do you need JSON? or is it just a matter of preference?
I want to make a web client for plex. just easier using json in javascript vs xml imo. XML will work fine though.
-nate
JSON would be much more light weight too
Like with most just add:
‘Accept’: ‘application/json’
to your headers.
It works. I use this.
I have tried this both from my app and SOAP UI. This does not work against plex.tv, will try it against the media server itself.
Edit: please ignore, can reach json versions by using the .json extension rather than a header.
Can you provide an example of the request URL to return json data?
This was a quick hack I did awhile back, it does have a serious bug… but enough to get going:
Did anyone got the json object out of plex media tv ?
