If I have a USB DAC plugged into the USB of my permanent android device for plaing audio, How can I keep it powered. Can I use a “Y” USB to both power and go to the DAC at one time.
Or is there any other solution to this?
You need a USB-C OTG Adapter with Power Delivery.
Or the obvious, wireless power for phone if it supports it ![]()
Yep thought off that…but cheap tablets don’t often come with wireless charging.. Experimenting with tablet control of headless ( as you suggested) vs running plexamp on the tablet. In both scenarios I want the ability to have audio out of the tablet for the occasional other media source like podcasts.
It’s a much better touch interface than the screen in my headless pi.
Thanks. I’ll try that
