Server Version#: Plex 1.19.4.2935-79e214ead, Ubuntu 20.04LTS
Followed the procedures from this link: Using EXT, NTFS, or other format drives (internal or external) on Linux
I was successful in creating the /disks and able to mount but the folder does not appear when adding to the library.
root@nuc:/# df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 16355156 0 16355156 0% /dev
tmpfs 3277072 3636 3273436 1% /run
/dev/mapper/vgubuntu-root 958876784 180491724 729607028 20% /
tmpfs 16385352 503380 15881972 4% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 16385352 0 16385352 0% /sys/fs/cgroup
/dev/nvme0n1p1 523248 7940 515308 2% /boot/efi
tmpfs 3277068 52 3277016 1% /run/user/1000
tmpfs 67108864 8 67108856 1% /tmp
/dev/loop17 107904 107904 0 100% /snap/plexmediaserver/104
/dev/sda1 960379920 79600 911445896 1% /disks/ssd
/dev/sdb1 11718850556 1077336328 10641514228 10% /disks/elements
root@nuc:/# blkid /dev/sdb1
/dev/sdb1: LABEL=“Elements” UUID=“640A32440A321410” TYPE=“ntfs” PTTYPE=“atari” PARTLABEL=“Elements” PARTUUID=“aa71774b-0777-40d5-ae0a-d7f243729e46”
I have the following in the /etc/fstab
UUID=640A32440A321410 /disks/elements ntfs defaults,auto,rw,nofail 0 1
root@nuc:/# ls -al /disks
total 16
drwxr-xr-x 4 yuji yuji 4096 Jun 11 21:51 .
drwxr-xr-x 22 root root 4096 Jun 11 21:50 …
drwxrwxrwx 1 root root 4096 May 27 21:45 elements
drwxr-xr-x 6 yuji yuji 4096 Jun 11 09:09 ssd
Weird thing is that I’ve chown and chmod the elements folder to yuji:yuji but it changes to root when mounted.
Could it be a permissions issue? Any assistance would be greatly appreciated.
