Library tabs not working - nvidia shield
Soo I have two libraries. One for Movies and one for TV shows. Today I started having a problem with my Nvidia shield plex client. Fx when I try to use the tabs in my movie library, fx the “collections” or “library” tab, it will instead show me my TV show content for that corresponding tab. After switching back and forth between the tabs in the library it will suddenly show me the right content. But if I try switching to another library the same bug will then start over for that library, which makes it quite annoying to navigate my content. I’m only having this problem on my shield. My server is running on a windows machine.
What im wondering if its a server problem or a problem with the shield app? And also if there is anything I can do to solve the problem.
Both my shield (player) and Windows PC (server) has the newest updates.
Server Version#: 1.25.8.5663
Player Version#: 8.31.2.31546
