Lifetime plugin
Are the movies with the plugin working for you shopgirl284? It doesn't look like your github has updated and the movie option is still erroring out.
Movies are working for me and the change was quite awhile ago, so it has gone through the system. Unless for some reason your Services bundle is not updating, movies should play for you.
I would need more info about your issue and your setup to try to diagnose the problem. Is it showing you a list of movies and giving an error when you play them or are you not able to even see a list of movies. What is your setup? What client are you using and what OS is your PMS machine? Are you using the latest version of PMS?
Also the channel system and the lifetime channel logs would be helpful. You can attach them with pastebin (http://pastebin.com/)
