Lightpack Support
Got my lightpack,and can't get the prismatik,software to recognize it on my Mac mini. I installed the software ahead of time and played around with it in virtual mode, now I can't get our of virtual mode. I uninstalled the software and reinstalled it but it's like nothing changed.
Any tips? The company that makes the lightpacks has HORRIBLE customer service
You just have to delete the config file (main.conf) and Prismatik should behave like the first time you opened it.
It's located in a hidden folder (.Prismatik) in your home folder, the easiest way would be to make sure you're in the Finder, choose Go > “Go to Folder.”, type "/Users/admin/.Prismatik" (replace admin with your user) and hit Go, now you should be se two folders and "main.conf", just delete that and you're done.
Did you get this working in the end
How are you finding it?
I'm close to ordering a lightpack myself. Any suggestions?
Mine arrived and it does work fine.
It is not (IMO) as good as the pukka Philips Ambilight but even with two packs at £200 it's a lot cheaper than a new set just to get some fancy lights.
For dead LED units though. :(
K.
What kinda suggestions are you looking for man?
I've a 40" TV and 1 lightpack is plenty for it, love it so far.
I’m loving mine!
Sent from my Nexus 7 using Tapatalk
That's about it. More of "it works great" or a "that's a terrible idea".
Thanks!
Hi all,
I also backed the lightpack project on Kickstarter.  I have it working great on my Hackintosh intel NUC running PHT.
I'm using a Harmony remote to control Plex and wanted to be able to turn the lightpack on/off switch profiles remotely.
I've gotten it to work pretty well.  I have 2 ways of doing this
  • a python script called by Applescript in keymaps/joystick.Harmony.xml
    • i.e. :       Plex.RunAppleScript(do shell script "~/bin/lp_remote.py off")
    • It's fairly simple..  Put the script and lightpack.py into a directory in your path (I use ~/bin).
    • lp_remote - select that profile (case sensitive) and turn on the lights
    • lp_remote off - turn lights off
    • lp_remote list - list available profiles
  • I've also created a plex channel to control the prismatik software.  It's in the early stages, but it does everything I need it to do.  Looking for suggestions/tips/etc.
What CPU usage are you getting?
Haven't checked. It's not affecting performance while watching, so I didn't really bother..
Edit:
Just checked using top..
Running a 720p video, PHT takes ~95-100%
Prismatik ~45%
On an i3-4130 running Windows 8, it's about 20% CPU for me.
Disabling Aero (and running the Aerolite theme) I get about 30fps, whereas with Aero I only get 20fps.
Screen grab delay 1ms.
Hi all,
 Thats great stuff, gonna try this during this weekend! Finaly got my Lightpack :)
Totally off topic, what settings are you using for your Harmony controller? Have a one of those, but cant get it working on my Intel Nuc with PHT. Would be nice to be able to hit one of the activites and boot up the computer. Or even controll PLEX with the remote. Feel free to PM as this has nothing to do with this topic.
Thanks a bunch!
Thanks a bunch!
To control Plex with Harmony: https://forums.plex.tv/topic/98676-what-remote-are-you-guys-using-to-control-pht/?p=600145
Thanks Lightpack scripts work great
Lately ive been noticing my Lightpack to cause tearing in videos, anyone else having this issue?
Can only have lightpack working on "Fullscreen windowed" rather than true fullscreen also :(
Yeah, I also noticed that it only works in fullscreen windows not true fullscreen
Anyone else? Thanks eubbenhadd
Thanks for the hard work YellowBee !! I've manually installed the channel and it is working great! Well... after a little tweak: I had to add the api key management in the prefs. As it is a very easy job to do it, I suppose there is a good reason why you didn't ? :)
Hello everybody that runs PHT in Windows (in my case Windows 7),
I used to have the same issue, lightpack was just running in fullscreen window and not in true fullscreen, the solution was:
01.  Run prismatik as administrator
02. Open prismatik settings
03. Click on the "Experimental" icon
04. Check the "Enable DX hooking" box under "Capture Source"
05. Run Plex and enjoy ;D
Hey
Yeah ive tried that, but it introduces a massive amount of tearing to the video
