Linux client
Hello all, new to the forums but have been using Plex for about 6 months and love it.
I saw in another thread that there was a linux client floating around these here forums:
http://forums.plexapp.com/index.php/topic/26908-any-eta-on-a-linux-client/
I have been unable to find it so I thought I'd see if it's true and where I might be able to get it.
I'm running Ubuntu 12.04 and would love to make it my total home theater soultion with a Plex client.
Thank you very much for any help, cheers.
http://forums.plexapp.com/index.php/topic/57542-ubuntu-ppa/
Wow, that was fast, thanks.
I am getting this error:
The following packages have unmet dependencies:
 plexhometheater : Depends: libcec (>= 1.7) but it is not installable
E: Unable to correct problems, you have held broken packages.
I installed libcec from Synaptic but it didn't help.  Any ideas how to fix this dependancy?
Thanks again.
I should include some background, eh..?
I ran:
sudo add-apt-repository ppa:plexapp/plexht
sudo apt-get update
sudo apt-get install plexhometheater
Then got:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
plexhometheater : Depends: libavcodec53 (>= 6:0.10.5~) but 4:0.8.4-0ubuntu0.12.04.1 is to be installed or
libavcodec-extra-53 (>= 6:0.10.6) but it is not going to be installed
Depends: libavfilter2 (>= 6:0.10.5~) but it is not going to be installed
Depends: libavformat53 (>= 6:0.10.5~) but 4:0.8.4-0ubuntu0.12.04.1 is to be installed
Depends: libavutil51 (>= 6:0.10.5~) but 4:0.8.4-0ubuntu0.12.04.1 is to be installed
Depends: libpostproc52 (>= 6:0.10.5~) but 4:0.8.4-0ubuntu0.12.04.1 is to be installed
Depends: libswresample0 (>= 6:0.10.5~) but it is not installable
Depends: libswscale2 (>= 6:0.10.5~) but 4:0.8.4-0ubuntu0.12.04.1 is to be installed
Then:
sudo add-apt-repository ppa:jon-severinsson/ffmpeg
Updated, re-tired
Tem got the lates error..
Thanks for any help!
I ran:
sudo apt-get update
Then got:
Then:
Updated, re-tired
If you read through the other thread you will find the answers you're looking for: http://forums.plexapp.com/index.php/topic/57542-ubuntu-ppa/#entry360119
Thank you drzoidberg33.  For some reason, after I added the 2 other repo's as you suggested, it stll gave me the same error.  I had to load the libcec package from Synaptic, and after that, it installed fine.  Thank you very much for the help.
I've been using a mac mini for 6 months or so as my media center with Plex.  I just built a new computer this week and am very glad to have Plex HT running on it!  Excellent job folks.
I have been waiting for a Linux Plex client for a very long time and I'm now patiently waiting for the next release because all my music is in FLAC and these don't play at all on the current builds.
I also have quite a bit of my music in FLACC and was wondering when support would be implemented.  Plex is getting better by the day.
Didn't really want to start a new thread for this so I'll ask here. I went with Xubuntu 13.04 and I am seeing talk of ubuntu 13 not working with PlexHT just yet. Am I totally hozed and need to start over with the last LTS?
Hi, I installed plexHT and the instalation went fine :
~$ sudo apt-get install plexhometheater
The following extra packages will be installed:
  libshairport1 libva-glx1
The following NEW packages will be installed:
  libshairport1 libva-glx1 plexhometheater
0 upgraded, 3 newly installed, 0 to remove and 7 not upgraded.
Need to get 32.0 MB of archives.
After this operation, 58.1 MB of additional disk space will be used.
Do you want to continue [Y/n]?
Get:1 http://ubuntu.linux-bg.org/ubuntu/ precise/universe libshairport1 amd64 1.2.1~git20120110.aeb4987-1 [25.8 kB]
Get:2 http://ppa.launchpad.net/plexapp/plexht/ubuntu/ precise/main plexhometheater amd64 0.9.9.7-201303220806-ubuntu33~precise1 [31.9 MB]
Get:3 http://ubuntu.linux-bg.org/ubuntu/ precise/main libva-glx1 amd64 1.0.15-4 [10.9 kB]
Fetched 32.0 MB in 34s (938 kB/s)
Selecting previously unselected package libshairport1.
(Reading database ... 423510 files and directories currently installed.)
Unpacking libshairport1 (from .../libshairport1_1.2.1~git20120110.aeb4987-1_amd64.deb) ...
Selecting previously unselected package libva-glx1.
Unpacking libva-glx1 (from .../libva-glx1_1.0.15-4_amd64.deb) ...
Selecting previously unselected package plexhometheater.
Unpacking plexhometheater (from .../plexhometheater_0.9.9.7-201303220806-ubuntu33~precise1_amd64.deb) ...
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf.index...
Processing triggers for desktop-file-utils ...
Processing triggers for gnome-menus ...
Setting up libshairport1 (1.2.1~git20120110.aeb4987-1) ...
Setting up libva-glx1 (1.0.15-4) ...
Setting up plexhometheater (0.9.9.7-201303220806-ubuntu33~precise1) ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
until I tried to run it and I got this  :wacko:  :
:~$ plexhometheater.sh
ERROR: Unable to create GUI. Exiting
Exiting Plex Media Server queue...
Segmentation fault (core dumped)
I google it, but I couldn't find anything about that, and I am not that good in linux as well. Please, if anyone have idea what is going on and how to fix that error. Thanks
The system is 12.04 (precise) 64-bit, 3.2.0-45-generic, GNOME 3.4.2
How do I get permission to access the link to the ubuntu app? I get permission denied when I click on the link.
You need to purchase Plexpass during the beta phase: https://my.plexapp.com/subscription/about
Or wait until it gets released to the public.
Or compile it from source: https://github.com/plexinc/plex-home-theater-public
/Mark
Sorry to drag this up,but I've tried to access the linked thread, and get an error stating that I don't have permission to view the thread. I'm at the stage the previous poster was, but am obviously missing something in trying to install this...Can anyone assist?
Thanks in advance.
Thanks in advance.
It's a Plexpass only thread. Until the Linux client + win/Mac get out of beta access to it is limited.
-Mark
- Mark
