I am specifically referring to the “4163 regression”.
They’ve all told me the regression which happened after 4163 is released in PlexPass today.
I’ve seen the QA reports.
Was something missed and can you capture please in the DEBUG logs so I can go back over them?
Functional question: Are you letting it play normally -OR- are you “seeking” during playback.
Seeking during Playback problem is still open. That fix is not yet complete & released.
There was no PlexPass version released today - 1.22.3.4392 moved to Public however.
The regression @riiviin and I are experiencing is lack of HW transcoding for HDR → SDR (which has been broken since 1.22.0.4163 and remains broken).
There are other complaints around regarding 11th gen HW transcoding issues, which as you allude to are likely kernel/driver related as those processors are still brand new.
Our 10th gen’s worked perfectly for HW HDR → SDR until versions post 1.22.0.4163.
Once you are able to get on the NUC10 and do some testing you will see what we mean.
I took the logs from @riiviin and forward to both the team member and director telling them both this is not fixed as claimed.
The NUC is in the lab.
The OS currently loaded on it is being replaced with Ubuntu 20.04.2 LTS so I can capture and demonstrate this myself which affords engineering with a system they can touch and use to fix
I got more time to work on this today and refine it.
- OpenCL is required if either Beignet or IntelComputeRuntime is used
- Reworked processor detection logic.
We shouldn’t have any more of the CPUSKU problems previously encountered.
I would appreciate a few folks with AMD, Xeon, and Intel -9xxx or higher giving this a quick run and providing feedback letting me know if it’s correctly surveyed the machine and installed libraries (HDR related)
It’s just the preinstall script.
It will generate /tmp/plexinstaller.log file which reports what was found and what’s needed during actual installation & configuration.
Fixed – below
# Plex Media Server installation configuration info: Fri 23 Apr 2021 06:03:49 PM EDTplexmediaserver_1.22.3.4392-d7c624def_amd64.deb
LangEncoding="en_US.UTF-8"
ExistingVersion=12200
HaveHardware=1
HaveTranscoderPref=1
NeedUser=0
NeedGroup=0
NeedVideo=0
Verbose=1
Running=0
Errors=0
Warnings=0
HaveIntel=1
HaveIntelCore=1
HaveIntelXeon=0
Havei915=1
HaveNvidia=0
Processor=i5-10600K
CPUSKU=10600
NeedBeignet=0
NeedIntelCompute=1
HaveIntelGmmlib=1
HaveIntelIGCCore=1
HaveIntelIGCOpenCL=1
HaveIntelOpenCL=1
HaveIntelOCLoc=1
HaveIntelZeroGPU=1
HaveIntelCompute=1
HaveBeignet=0
HaveOpenCL=1
Platform="System Product Name"
Processor="i5-10600K"
Distro="Ubuntu 20.04.2 LTS"
Kernel="Linux Saturn 5.8.0-50-generic #56~20.04.1-Ubuntu SMP Mon Apr 12 21:46:35 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux"
Memory=""
Looks good, though “Memory” did not return any result. Did you experience the lack of HW HDR → SDR on the NUC10?
Ubuntu 20.04.2 LTS
CPU: Intel i7-9750H
GPU: NVIDIA GeForce RTX 2080 Mobile
plexinstaller.log (774 Bytes)
Thank you both.
I see where I lost that in the overhaul.
Fixed now.
ChuckPa-preinst.zip (8.8 KB)
chuck@plexdev:~/git/postprocessor/targets/debian/files/debian$ ./ChuckPa-preinst.sh
rm: cannot remove '/tmp/plexinstaller.log': Operation not permitted
chuck@plexdev:~/git/postprocessor/targets/debian/files/debian$ sudo !!
sudo ./ChuckPa-preinst.sh
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Warning: Multiple override files found. PMS may not function as expected.
PlexMediaServer install: Files found are: Another.conf override.conf
PlexMediaServer install: Selected: "override.conf".
PlexMediaServer install: Warning: "/var/lib/plexmediaserver/Library/Application Support" isn't owned by "plex", UID: 998. Found "UNKNOWN", UID: 12345 instead. Continuing.
PlexMediaServer install: Pre-installation Validation complete. Errors: 0, Warnings: 2
chuck@plexdev:~/git/postprocessor/targets/debian/files/debian$ cat /tmp/plexinstaller.log
# Plex Media Server installation configuration info: Fri Apr 23 18:38:49 EDT 2021plexmediaserver_1.22.3.4392-d7c624def_amd64.deb
ExistingVersion=12203
HaveHardware=1
HaveTranscoderPref=0
NeedUser=0
NeedGroup=0
NeedVideo=0
Verbose=1
Running=0
Errors=0
Warnings=2
HaveIntel=1
HaveIntelCore=1
HaveIntelXeon=0
Havei915=0
HaveNvidia=0
Processor=i7-8809G
CPUSKU=0
NeedBeignet=0
NeedIntelCompute=0
HaveIntelGmmlib=0
HaveIntelIGCCore=0
HaveIntelIGCOpenCL=0
HaveIntelOpenCL=0
HaveIntelOCLoc=0
HaveIntelZeroGPU=0
HaveIntelCompute=0
HaveBeignet=0
HaveOpenCL=0
Platform="VMware Virtual Platform"
Processor="i7-8809G"
Distro="Ubuntu 18.04.2 LTS"
Kernel="Linux plexdev 4.15.0-45-generic #48-Ubuntu SMP Tue Jan 29 16:28:13 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux"
Memory="3921 1035 717"
Be advised:
If in a VM and no i915 enumerated, CPUSKU = 0.
# Plex Media Server installation configuration info: Fri 23 Apr 2021 05:39:00 PM CDTplexmediaserver_1.22.3.4392-d7c624def_amd64.deb
HaveHardware=1
NeedUser=0
NeedGroup=0
NeedVideo=0
Verbose=1
Running=0
Errors=0
Warnings=0
HaveIntel=1
HaveIntelCore=1
HaveIntelXeon=0
Havei915=1
HaveNvidia=0
Processor=i7-10710U
CPUSKU=10710
NeedBeignet=0
NeedIntelCompute=1
HaveIntelGmmlib=1
HaveIntelIGCCore=1
HaveIntelOpenCL=1
HaveIntelOCLoc=1
HaveIntelZeroGPU=1
HaveIntelCompute=1
HaveBeignet=0
HaveOpenCL=0
Platform="NUC10i7FNH"
Processor="i7-10710U"
Kernel="Linux nuc 5.11.14-051114-generic #202104140732 SMP Wed Apr 14 07:55:50 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux"
Memory="31820 1477 1290"
Now we’re cookin’
You should find that if you install ocl-icd-opencl1, it will stop complaining about OpenCL.
This is experimental:
- New packaging for Comet and RocketLake CPUs
- Proposed PMS transcoder changes
- Other miscellaneous breakages
This is NOT FOR PRODUCTION USE - NOT QA TESTED - WORK IN PROGRESS
GOALS:
Proper detection of:
a. CPU
b. Type of HDR support needed: Beignet or Intel Compute Runtime -
Fully & Correctly populated plexinstaller.log
If we’re lucky, a working transcoder capable of pre 1.22.0.4163 capabilities + more
Ran your updated script and below is my log
plexinstaller.log (789 Bytes)
Still seeing CPUSKU=0 but not sure if that is a problem or not based on my system and the fact I have a dedicated GPU.
Still no hardware transcode for HDR to SDR.
PlexMediaServer install: PlexMediaServer-1.23.0.4412-9b095e06b - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: timstephens24
PlexMediaServer install: Plex Group: timstephens24
PlexMediaServer install: Video Group: render
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /tmp
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Config file used: /etc/systemd/system/plexmediaserver.service.d/override.conf
PlexMediaServer install: Intel QSV Hardware: Found
PlexMediaServer install: Nvidia GPU card: Not Found
PlexMediaServer install: OpenCL library: Installed
PlexMediaServer install: Beignet package: Installed
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.23.0.4412-9b095e06b - Installation successful. Errors: 0, Warnings: 0
# Plex Media Server installation configuration info: Sat Apr 24 08:44:37 AM EDT 2021
Init=0
Systemd=1
Custom=0
LinuxContainer=0
NewInstall=0
HaveOverride=1
OverrideFile="/etc/systemd/system/plexmediaserver.service.d/override.conf"
PlexUser="timstephens24"
PlexGroup="timstephens24"
VideoGroup="render"
AppSuppDir="/var/lib/plexmediaserver/Library/Application Support"
PlexTempDir="/tmp"
HaveHardware=1
NeedUser=0
NeedGroup=0
NeedVideo=0
Verbose=1
Running=1
Errors=0
Warnings=0
Havei915=1
HaveNvidia=0
HaveBeignet=1
HaveOpenCL=1
Platform="Z490 VISION D"
Processor="Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz"
Distro="Ubuntu 20.10"
Kernel="Linux zeus 5.8.0-50-generic #56-Ubuntu SMP Mon Apr 12 17:18:36 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux"
Memory="64162 5728 1798"
Look at your plexinstaller.log. There’s something really bad here. You don’t even have all the flags
chuck@plexdev:~/git/postprocessor$ cat /tmp/plexinstaller.log
# Plex Media Server installation configuration info: Sat Apr 24 10:05:52 EDT 2021plexmediaserver_1.22.3.4392-d7c624def_amd64.deb
HaveHardware=1
NeedUser=0
NeedGroup=0
NeedVideo=0
Verbose=1
Running=0
Errors=0
Warnings=2
HaveIntel=1
HaveIntelCore=1
HaveIntelXeon=0
Havei915=0
HaveNvidia=0
Processor=i7-8809G
CPUSKU=0
NeedBeignet=0
NeedIntelCompute=0
HaveIntelGmmlib=0
HaveIntelIGCCore=0
HaveIntelOpenCL=0
HaveIntelOCLoc=0
HaveIntelZeroGPU=0
HaveIntelCompute=0
HaveBeignet=0
HaveOpenCL=0
Memory="3921 1075 1023"
Same results as @timstephens24 with 1.23.0.4412 - no HW HDR → SDR, and also missing flags in plexinstaller.log
# Plex Media Server installation configuration info: Sat 24 Apr 2021 10:34:24 AM EDT
Init=0
Systemd=1
Custom=0
LinuxContainer=0
NewInstall=0
HaveOverride=0
OverrideFile=""
PlexUser="plex"
PlexGroup="plex"
VideoGroup="video"
PlexTempDir="/dev/shm"
ExistingVersion=0
HaveHardware=1
NeedUser=0
NeedGroup=0
NeedVideo=0
Verbose=1
Running=1
Errors=0
Warnings=0
Havei915=1
HaveNvidia=0
HaveBeignet=0
HaveOpenCL=1
Processor="Intel(R) Core(TM) i5-10600K CPU @ 4.10GHz"
Memory="31942 1382 14061"
Binary withdrawn – Too experimental
Please verify a full set of flags in plexinstaller.log
# Plex Media Server installation configuration info: Sat Apr 24 10:40:15 EDT 2021
Init=0
Systemd=1
Custom=0
LinuxContainer=0
NewInstall=0
HaveOverride=1
PlexUser="plex"
PlexGroup="plex"
VideoGroup="video"
PlexTempDir="/tmp"
ExistingVersion=12300
HaveHardware=1
NeedUser=0
NeedGroup=0
NeedVideo=0
Verbose=1
Running=0
Errors=0
Warnings=2
HaveIntel=1
HaveIntelCore=1
HaveIntelXeon=0
Havei915=0
HaveNvidia=0
Processor=i7-8809G
CPUSKU=8809
NeedOpenCL=0
NeedBeignet=0
NeedIntelCompute=0
HaveIntelGmmlib=0
HaveIntelIGCCore=0
HaveIntelOpenCL=0
HaveIntelOCLoc=0
HaveIntelZeroGPU=0
HaveIntelCompute=0
HaveBeignet=0
HaveOpenCL=0
Memory="3921 1087 1358"
Here’s what I got:
PlexMediaServer install: Intel i915 Hardware: Found
PlexMediaServer install: OpenCL: Installed
PlexMediaServer install: Intel Gmmlib: Installed
PlexMediaServer install: Intel IGC Core: Installed
PlexMediaServer install: Intel IGC OpenCL: Installed
PlexMediaServer install: Intel OpenCL: Installed
PlexMediaServer install: Intel OCLoc: Installed
PlexMediaServer install: Intel Zero GPU: Installed
# Plex Media Server installation configuration info: Sat Apr 24 10:59:47 AM EDT 2021
Init=0
Systemd=1
Custom=0
LinuxContainer=0
NewInstall=0
HaveOverride=1
VideoGroup="render"
PlexTempDir="/tmp"
HaveHardware=1
NeedUser=0
NeedGroup=0
NeedVideo=0
Verbose=1
Running=0
Errors=0
Warnings=0
HaveIntel=1
HaveIntelCore=1
HaveIntelXeon=0
Havei915=1
HaveNvidia=0
Processor=i7-10700K
CPUSKU=10700
NeedOpenCL=1
NeedBeignet=0
NeedIntelCompute=1
HaveIntelGmmlib=1
HaveIntelIGCCore=1
HaveIntelOpenCL=1
HaveIntelOCLoc=1
HaveIntelZeroGPU=1
HaveIntelCompute=1
HaveBeignet=1
HaveOpenCL=1
Processor="i7-10700K"
Memory="64162 5754 16691"
But that version of Plex isn’t running
Apr 24 11:02:13 zeus systemd[1]: plexmediaserver.service: Main process exited, code=dumped, status=11/SEGV
Apr 24 11:02:13 zeus systemd[1]: plexmediaserver.service: Failed with result 'core-dump'.
Please go grab the log files. Let’s see if there’s any indication in there as to why
If you see none, then please invoke manually and check for:
chuck@plexdev:/usr/lib/plexmediaserver$ ./Plex\ Media\ Server
DCRT: Failed to open ldso
Segmentation fault (core dumped)
If this is your finding then I will withdraw the above and hold back until a later binary from Engineering before bringing it here.
PMS 1.23.0 will contain the corrections we need for the -10xxx CPUs
There were no new logs created.
[1] 36064 segmentation fault (core dumped) ./Plex\ Media\ Server
