Linux plex service will not launch
I have been trying to get Plex media server to start as a service and I get the error below. I am not sure how to diagnose this. Any advise?
`sudo systemctl status -l plexmediaserver`
`● plexmediaserver.service - Plex Media Server`
`Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)`
`Active: failed (Result: exit-code) since Tue 2023-03-07 21:04:39 EST; 20h ago`
`Process: 1137 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR>`
`Process: 1139 ExecStart=/bin/sh -c export PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= "{print \$2}" | tr -d \" )"; export PLEX_MEDIA_S>`
`Main PID: 1139 (code=exited, status=1/FAILURE)`
`CPU: 113ms`
`Mar 07 21:04:39 mediacenter systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.`
`Mar 07 21:04:39 mediacenter systemd[1]: Stopped Plex Media Server.`
`Mar 07 21:04:39 mediacenter systemd[1]: plexmediaserver.service: Start request repeated too quickly.`
`Mar 07 21:04:39 mediacenter systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.`
`Mar 07 21:04:39 mediacenter systemd[1]: Failed to start Plex Media Server.`
What linux dist?
How did you install? apt install plexmediaserver?
