Linux Server wont upgrade v 1.19
Thanks. The logs are clean but, as expected, end as of April 21
I did a bit of hackery yesterday with another user which worked out well in solving a problem.
I’d like to use that technique here to diagnose your system.
  1. Copy /usr/lib/plexmediaserver/lib/plexmediaserver.init to /tmp
  2. Open in an editor.
  3. Scroll down to the launch line (su -blah blah-exec)
  4. At the end of the line, find and remove the redirection to /dev/null as well as the background launch.
  5. Save
  6. As root, execute it with /tmp/plexmediaserver.init start
It will launch in foreground mode. Anything coming from PMS’ stdour or stderr will be printed in your terminal window.
Can you be more detailed about step 4 ?
change
su -m $PLEX_MEDIA_SERVER_USER -s /bin/sh -c "exec ${PLEX_MEDIA_SERVER_HOME}/Plex\ Media\ Server &" >/dev/null 2>&1
to
su -m $PLEX_MEDIA_SERVER_USER -s /bin/sh -c "exec ${PLEX_MEDIA_SERVER_HOME}/Plex\ Media\ Server"
is that right ? and how do I shutdown the background launch?
That’s right but someone is seriously wrong.
That’s not the code which should be there.
Please give me a few minutes to resolve this.
Thanks.
You’re ok to proceed.
What’s happened on my end, which surprised me, is I wasn’t seeing other changes which had been approved two weeks ago and should already be in the code.
I’ve messaged the team, pointing out the discrepancy , and asking them to help me resolve where it went. It’s probably a simple error to correct. (but that’s why i test a lot before releasing into production)
Per your questions:
  1. Any normal linux will show you the jobs the shell has in the background
  2. Just kill %x (where x is the job number) will stop that background task.
  3. This is the same as Ctrl-C when in foreground
@ChuckPa
so am I best starting with a fresh install and copy Plex across?
@ChuckPa
Is that what you need ?
root@aria2-server:/tmp# /tmp/plexmediaserver.init start
Starting Plex Media Server.
terminate called after throwing an instance of 'std::runtime_error'
  what():  locale::facet::_S_create_c_locale name not valid
Aborted (core dumped)
I think I might have intermixed two different issues by accident.
If you’d both please confirm for me?
@wopag
Your issue is isolated to preinstallation ?
@kingzleshe_sina_com
You can install but cannot run ?
@ChuckPa
can not run indeed
Your system isn’t configured properly.
This isn’t a plex problem but easily fixed.
https://www.ubuntugeek.com/how-to-select-and-generate-locales-on-ubuntu.html
Once the localization files have been defined, PMS will be able to start
@ChuckPa
wow It worked
If I may ask how did you know that is a localization files issue?
_S_create_c_locale name not valid “locale” is your machine’s localization.
@wopag
I use 19.10 here, a fresh installation, without issue.
If you upgraded from 15 -> 19 this is why.
Can you start over with a fresh installation of 19 (no more upstart) ?
I have to agree with @ChuckPa on this one, the general rule of thumb with Debian (and Ubuntu) upgrades is, your allowed one dist-upgrade and then its better to lay down a fresh OS for your next upgrade.
I’ll take the opportunity to move servers, update from an i5 to an i7.
fresh headless install of Linux too. consider my thread closed
