I think I already know the answer to this due to apples development limitations but I have to ask, is there a way to achieve a light background on everything instead of that black. One of the few things I don’t like about the Apple TV. Everything looks like it’s floating in space LOL …but seriously in my opinion it’s just too bland and I’m totally tired of it and have disliked it from day one. A nice “Plex Gray” background would be nice.
Install Cyberghost’s theme. He has different colour backgrounds.
Oh really didn’t know that, thanks for the heads up I will check that out.
Can someone please tell me where I can find this cyberghost theme and information on how to install it?
What PlexConnect host are you using?
https://github.com/CyberGhost84/PlexConnect
# Installation git clone https://github.com/CyberGhost/PlexConnect.git # Updating cd PlexConnect git pull
I’m using the trailers app, and Plex connect with pillow is running on my Windows 7 PC.
I looked at that page from the link, don’t really understand what I need to do, I need a step-by-step. Thanks.
So you have used PlexConnect before, and you need step by step instructions?
Download his Forked version of PlexConnect.ZIP or git clone his github, I assume you know the rest.
Got it, thanks again. Looks great what a fantastic job on development.
About the only thing I would change if I could would be poster size a tad smaller, but I still like them big and its certainly better than the small default ones I had. It’s amazing how talented you all are and what you’re able to do even without assistance or a paycheck from Apple Inc. A great community we have here.
Thank You
Switch to grid if you want them smaller.
Edit - misread your post. You want a size in between or a bit larger then in between the current size.
The current size posters of the large grid view is actually okay, I would just like to get rid of large gap spaces in between the posters so the edge of the posters are not pushed tight to the side of the screen. Looks cut off at times.Switch to grid if you want them smaller.
Tv shows is even worse, it's actually cut off.
If the posters have to be smaller to achieve this that would be fine, but if we could keep the big size and just move everything in more that would be even better. I have tried the adjust for overscan on and off in my AppleTV settings and it makes no difference. So I figure it's got to be the design of the theme.
Would love to play around with this type of stuff if I knew how.
Best thing todo is open a github account and stick a fork in his repo. I believe the files you are looking for are in here:
PlexConnect/assets/templates/TVShow
https://github.com/CyberGhost84/PlexConnect/blob/master/assets/templates/TVShow/BigArtwork.xml
PlexConnect/assets/templates/Movie
https://github.com/CyberGhost84/PlexConnect/blob/master/assets/templates/Movie/BigArtwork.xml
You need to change the 560 or 840 numbers not 720 or 1080 depending on what aTV you have. 720=1080 is for aTV2 or aTV3 set to 720p (Rare) and 1080=840 is only for aTV3.
i dont believe this is the problem, i use the large artwork swell for the season view and i have the same problem with the edges being to close.. this is also on my atv2 without fanart so i think something else is acting up.. just can't find what it is though..
We should ask the ghost in the machine ;) I sent him a iMessage. You sure your aspect ratio/zoom is correct on your tv's?
https://www.youtube.com/watch?v=l0QahH1zlUQ
At 45 seconds you can clearly see no edges.
tv zoom
ur tv screen settings are bad
bad TvScreen Settings. Set to standard instead of zoom or ....
i have tried it on 5 different tvs. and with all the different settings... all with the same result.. dunno whats going on,,,
overscan on the atv seamed to do the trick
maybe idk.. (it just has nothing to do with xml code)
i know that i could also be the tvscreen settings.
yeah got it working here at my parents house.. il se if i can make it work at home to when i get home..
