@dansmith21 said:
More to the point: the HDHomeRun app plays things back just fine, without any further processing. So any extra transcoding/etc. is demonstrably unnecessary.
@ataboyx1 said:
My question is, if WinTV8 can handle the live stream without transcoding why can’t Plex?
Have either of you tried to put a Windows/Linux VM on your NAS and boot it, remote to it, install the TV app, and watch videos using client apps for the TV tuner on the NAS? (If so, please, let me know how that went)
Though much more complexity is involved, the simplest answer applies to you both.
Plex server is designed to do the heavy work so your client devices don’t have to.
Most apps (HDHomerun/WinTV8/VLC/whatever) do all the conversion work on the client end, where as Plex is majority designed to do the work on the server, using profiles that tell the transcoder what the (supported/known) client device talking to it are capable of.
Due to support of multiple devices in the same ‘family’, the profile may contain information that works on the oldest device. Example, my years old Ipad2 won’t do the capabilities my newest Ipad Pro will, but sure enough, Plex plays on them both with no issue.
Plex devs have, do, and occasionally will make multiple profiles.
That doesn’t mean every profile is tweaked for the highest end latest greatest client though.
Perfect example, the IOS phone - plex has 6 profile files for them - reality though… most point to 2 actual files. So, no matter what IOS phone you have, you get one profile or another.
I’ve not looked, but I get the idea my Roku would be the same - several profiles, but only 2-3 real ones depending on age of device.
I understand you want to use all the great features Plex has to offer, but, low power CPUs are not normally capable of doing all Plex can.
