LiveTV with Rasplex. Skin?
does anyone know of a skin for Rasplex that includes LiveTV? Today I have to change the skin to Confluence in order to be able to access Live TV and its functions such as the EPG.. and it simply to much of a hazzle (and I'm running Refocus as the "primary" skin")
(I'm using seperate machine with Windows MediaCenter and I wish to manage the recordings through Rasplex)
I don't think RasPlex will get LiveTV support by using the XBMC feature… There are github issues for that but there are just not enough devs to work on this.
It would be much cooler to have a PMS channel which provides LiveTV for all Plex clients … much more flexible and generic.
Thanks for the response and I totally agree with you - having it as a channel would be the ideal solution
Skickat från min Galaxy Nexus med Tapatalk 4
http://forums.plexapp.com/index.php/topic/58831-dreambox-plugin-01-is-done/page-14
Cool.
For now I've solved it though - I am using client side functionality in XBMC with the Windows MediaCenter plugin and I've done my own mod of reFocus with LiveTV views/functionality from Confluence. Works exactly as I want it to do.
