Lock for Plex Google Chrome App
https://twitter.com/lockforplex/status/663283582832480256
Thanks, here's the log file (attached)
Hi - I found 2 instances and modified as suggested.
Trying to open the channel now it seems to get stuck in a loop ("loading" on Android, spinning circle on web app )& times out ("directory appears to be empty" Android, "Server unavailable", web app)
(Scripts still work manually)
I've sent a message to BlitzTKO asking for some advice
Hey guys - sorry I've been MIA lately - been really busy with work.  kc1 - please send me the log files, and I'll see if I can dig through them for anything.  Also, for your Synology - can you also let me know what version?  That way we can determine if it's an ARM processor or not, but not entirely sure if that sure matter.  Also, let me know the results of uname -a for machine if you're able to run a terminal.
iSh0w - I'll also give your latest build a shot either tonight or tomorrow, have been swamped and haven't been able to give it a go as of yet.
Hi, Thanks for your help with this.
It's a DS 412+ (Intel Atom, I think)
uname -a comes back with:
Linux Box3 3.2.40 #4977 SMP Sat Sep 20 02:12:25 CST 2014 x86_64 GNU/Linux synology_cedarview_412+
The logs are attached (there now seem to be several files).
Love this plugin for Plex but the latest version isn't working for me (the older version works fine)
I have Plex running on Windows 7 but running the lock doesn't do anything. The bat file looks wrong to me, SQLite doesn't seem to be called like it was in the old version but I am no expert.
This is what my Lock bat file looks like
set "l0ckplex="UPDATE metadata_items SET metadata_type=20 WHERE library_section_id=1 and metadata_type=1; DELETE FROM library_sections WHERE id=1;""
undefined
undefined %l0ckplex%
exit
Thank you for your appreciation of the plugin :) helps to motivate myself to spend time on L0ck.
Yes, thank you for bringing this blunder on my part to my notice, fixed the issue. Pl. revert if the issue still isn't resolved!
Thanks.
/iSh0w
Sent from my iPhone using Tapatalk
Your fix worked great, thanks for the quick response.
Yes this plugin works great for me and its maybe easier than having separate logins for my kids as I can just lock and unlock at will.
I have done a little playing around and created two separate locks for different sections so I can unlock whichever section I need, just a folder rename and a slight edit of the code and it works a treat!
Also, I had Plex HT running on the same box as Plex Media Server and every time I ran L0ck it would minimize Plex HT which was a pain. I have got round this by using a simple VBS script which allows L0ck to run silently in the background and not minimize Plex HT
I've haven't been able to figure it out by myself how to get the channel working on a Synology, but I did find a useful way to switch the lock on and off in just 2 clicks using and Android app called SSH Button (creating shortcuts to login via SSH commands and run the scripts "manually").
Would this locking/unlocking work with a non-Plex DLNA client? e.g. Xbox One Media Player Preview app?
Alright - sorry I've been MIA - been a crazy couple of weeks with work and what not....
iSh0w - like the updates to the L0ck page and the new graphics - looks nice...
Ok, for starters - setup.sh need path updates - you have it in the l0ck_support dir - so need to update as per following:
chown -R plex:plex ../../../../L0ck.bundle
chmod a+x l0ck.sh
chmod a+x unl0ck.sh
chmod a+x sqlite3
Not sure if you want to include the Restart PMS step in the installation instructions as well.
Everything else looked good, confirmed Lock working from Browser and Unlock from Android device.
Now on to helping others...
Yeah, sorry - when it comes the Synology version of the app, I'm at a loss there.  I myself have a synology, but running an ARM processor so Plex is not supported on it.  I run PMS off a dedicated Linux server.  I know the browser version of L0ck only handles the "locking" of the library - I have to use my android device to unlock again through Plex itself.
I as created my own shell scripts to make the lock/unlock calls that I can access through an app outside of Plex - so I'm with you there.
Are the libraries at least locking and unlocking when you call the script manually?
I tried it with Xbox One Media Player Preview. The lock shows up in the Video Channels. Unfortunately, only the locking part works with this DLNA client. There is no place to enter password for unlocking.
Changed the linux bit, pl. revisit the L0ck generator page and generate and give it a try, appreciate if you (advanced linux user)....
Definitely not advanced!.  Here's what happened: at the generator page:
Sorry, your Plex Media Server(Box3) version( 0.9.9.14.531-7eef8c6 ) running on operating system Linux  (#4977 SMP Sat Sep 20 02:12:25 CST 2014) is currently NOT supported!...
