Lock for Plex Google Chrome App
Hey Mihai,
You need to change your paths.
You can read up about it on the FAQ page. Read the answer to the question "I have a custom linux box and I managed to get a hold of L0ck, shhh! :D, but it does not work or do anything, why ?"
Thanks,
/iSh0w
Hey iSh0w,
I did exactly those steps before. Have you checked the files in quote before ? There I have given all the path. e.g. media/645f4371-4869-43f4-b76d-b29ceb355057/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Plug-ins/L0ck.bundle/Contents/Resources/l0ck_support/.
I also changed the paths in the config ' __init__.py ' .
The only thing which is NOT working for me is chown plex:plex, since there is no group plex within my OMV. My plex instance is running with plex:nogroup and all the files having 755 permission. Ist there anything to be changed ?
Regards,
mihai
https://twitter.com/lockforplex/status/663283582832480256
Hi iSh0w,
root@OMV:/media/645f4371-4869-43f4-b76d-b29ceb355057/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/L0ck.bundle/Contents/Resources/l0ck_support# ./l0ck.sh
-bash: ./l0ck.sh: Keine Berechtigung
Keine Berechtigung means = like no permissions to execute it. But I am root and the permissions and ownership are as follows:
root@OMV:/media/645f4371-4869-43f4-b76d-b29ceb355057/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/L0ck.bundle/Contents/Resources/l0ck_support# ls -al
insgesamt 596
drwxr-xr-x 2 plex nogroup   4096 Mär 24 13:21 .
drwxr-xr-x 3 plex nogroup   4096 Mär 24 13:21 ..
-rwxr-xr-x 1 plex nogroup    652 Mär 25 10:30 l0ck.sh
-rwxr-xr-x 1 plex nogroup 590452 Mär 24 13:21 sqlite3
-rwxr-xr-x 1 plex nogroup   1293 Mär 25 10:30 unl0ck.sh
I have also tried once to setup the ownership also as root:root without success.. Same issue -- no permission
Regards,
mihai
root@OMV:/media/645f4371-4869-43f4-b76d-b29ceb355057/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/L0ck.bundle/Contents/Resources/l0ck_support# su
root@OMV:/media/645f4371-4869-43f4-b76d-b29ceb355057/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/L0ck.bundle/Contents/Resources/l0ck_support# chmod +x l0ck.sh
root@OMV:/media/645f4371-4869-43f4-b76d-b29ceb355057/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/L0ck.bundle/Contents/Resources/l0ck_support# chmod +x unl0ck.sh
root@OMV:/media/645f4371-4869-43f4-b76d-b29ceb355057/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/L0ck.bundle/Contents/Resources/l0ck_support# chmod +x sqlite3
After doing that, its still showing the same. Any idea why it is like that?  which permission is missing here and how to set it ?
I also tried to login as a normal user. From there I did sudo chmod a+x l0ck.sh etc. Tried to exectue ./l0ck.sh --> no luck, it is still showing the same error.
I also tried to su than. Gave the root PW --> root than, tried to chmod +x the files --> execute --> no luck...
I am asking me, why I am unable to execute it as root ? root should at least have the permission to execute everything. :D If root does not have, who than ? Do I have to create another grouß in my OMV ? just let me know
Regards,
mihai
Regards,
mihai
I now got it running, that I can execute ./l0ck.sh and ./unl0ck.sh. It is also locking and unlocking the sections in PMS if I rund the commands from shell.
The problem was, that the HDD in the OMV was mounted using noexec, thats why I was not able to execute the scripts. ( you can see that in fstab, or just if you run mount )
However, when I try to lock the sections through PMS, its not working. Also unlocking the sections through PMS, after I locked them through the backend, is not possible. Any idea, where I have to check, why that is not working from PMS ?
Regards,
mihai
Hello
I'm on windows 8.1 with plex media server 0.9.1116,
I wanted to try l0ck so i follow all steps but after restarting the server
i can't see the new channel for l0ck, no button.
I've got other channels working, lhe l0ck plugin is in the good folder,
i don't understand so if you've got any ideas Thanks
Hi there.
Just discovered this and it works well on my OSX Mavericks.
The only question i have is there a way to disable the terminal popup on my Mac every time the channel is used to lock or unlock?
http://stackoverflow.com/questions/5560167/how-should-i-properly-exit-terminal-using-a-terminal-command-on-mac-os-x
in Terminal.app
Preferences > Settings > Shell
on 'When the shell exits' chosen 'Close the window'
in Terminal.app
Perfect!
Thanks J
I'm on Win7, I could install and run l0ck and unl0ck with python but it doesn't do anything. I could still access all folders. any idea?
https://www.youtube.com/watch?v=nSQ59fn6Qfw
@lockforplex
Hi there.
With today’s release for iOS it seems to have broken lock. I can’t get the unlock option to appear.
