Lock for Plex Google Chrome App
@pommybloke said:
Hi there.
With today’s release for iOS it seems to have broken lock. I can’t get the unlock option to appear.
same here :frowning:
i asked the question here, seems the search for channels is missing
https://forums.plex.tv/discussion/176600/search-function-within-channels-missing#latest
https://twitter.com/lockforplex/status/663283582832480256
@L0ck for Plex said:
/iSh0w
Sorry I should have said, its not just for iOs, i also tried running the plugin on my Mac using Plex Web and it didnt work there either.
All it shows is ‘Lock’ and ‘Update Feed’.
When i click on ‘Lock’ it doesnt do anything. And the opening hte channel again still displays the same options.
Hello, in Ubuntu 14.04.I use Firefox (unable to get Chrome installed)
Can I use this with Firefox?
Ok, I’ll try that. Do I put the password in the search field to lock and to unlock? that would be good. or do I have to go to the lock channel every time I need to lock it again? are you able to add the feature to lock/unlock specific Channels? Thx
Ok, one last thing :slight_smile: will this work with the Roku Plex channel?
are you able to add a feature to be able lock/unlock specific Channels?
Not at the moment, no. :confused:
/iSh0w
Ok, please keep me updated as that is all I would need it for then would happily pay the 0.99 cents because the new version of Plex for Roku removed all personalize settings. I’ve had to install the Plex Classic app for Roku to keep the ‘Hide Channels’ option from home screen but that hides all channels and doesn’t auto hide after an hour like your cool app. I haven’t tested your program yet with the Roku Plex app.
Having the ability to hide specific channels would be awesome
