Lock for Plex Google Chrome App
Hello tomatosmoothie,
I run into “You were able to sign-in but your server settings prevented lock for plex from reading your data” even when changing the network encryption to preferred or off and restarting plex. Tried logging out my user.
Ive disabled pincode for my user… im only connected to one server.
Even tried disabling the firewall (got the server on fedora 24)
Cant find anything in ur FAQ mentioning anything else, what am i missing?
Best Regards,
Robin
Best Regards,
Robin
I’d suggest opening plex/web in the same browser, preferably open a tab next to the loaded plex/web tab and load lockforplex.com - Suggest using basic security and both the PIN method of the sign-in method should be good to go.
Are you signing in to lockforplex.com from the same machine where you have your plex media server?
Best Regards,
Robin
I’ve been opening plexwebapp and lockforplex in different tabs on chrome from a computer on the same LAN.
I’ve also tried from the fedora machine where i have the plex server itself and i get the same thing.
Basic security as in removing pin and allow non-enctrypted connections? (What ive been trying)
Best Regards,
Robin
Strange. Yeah, basic security as in just a simple sign-in to plex media server and no added layers of security.
Tried it right now, working fine.
Best Regards,
Robin
Does it ever come in to play that its fedora? Regarding who owns the files etc. Currently me as a user is owner, but plex have full access. Since well yea it’s working. Just so weird :confused:
Best Regards,
Robin
I don’t think that Fedora would be an issue wrt connecting, you could give folks in the linux sub-forums a shout and ask them to give lockforplex.com a go =D
Best,
Season Greetings!
Visit http://lockforplex.com for to use the free beta web app version.
Will be updating as and when (look for updates within lockforplex.com > releases).
Will not be actively posting in this forum. If you face any issues or need help, send me a direct message on my twitter handle - tomatosmoothie
Cheers!
Mark
Now i even tried setting up a new plex server on this windows 10 machine, with a new user and email. Basic settings everything. Added a library and tried using lockforplex, still the same issue. Side note: the earlier lock for plex app actually worked if i used it from the fedora server itself before. So this new one doesnt work at all for me.
I suppose that other people aint experiencing this because they already have the plugin “all set” since before.
I am having the same issue. It’s not working in Mac Chrome.
http://LockForPlex.com
  • Latest update lets users choose their server, based on requests from users that own multiple servers connected to the same plex id
  • More specific warning messages while connecting
Connect via twitter @tomatosmoothie you need not follow me, anyone can send me a message via twitter without following me! I am rarely active on the plex forum.
https://twitter.com/tomatosmoothie
Just want to say thanks for your hard work, your latest updates made it work for me instantly which is greatly appreciated!
I love this plugin. Just one suggestion. The PIN is plainly visible in the py file. It should be at least masked using even a simple rudimentary masking logic so its not clearly usable by just looking at the file :slight_smile: Just my 2 cents. Thanks again for this great plugin !
14 Feb 2017
  • Revamped the way Lock for Plex gets section information
  • Added Google Sign-in
  • UI Changes
  • Code clean-up
https://redchiliflakes.gitlab.io/lockforplex/
Where’s the preferred place to go for support of this plugin? The install link above says Reddit, however it appears to be locked down.
Here’s the problem… it doesn’t appear to work with CentOS 7 and Plex 1.10.1.4602.
The plugin generates fine. When I go to install it I see the channel, so all’s good there too. When I select the “lock” and “unlock” buttons, they both appear to work, but nothing actually happens.
In the lock_support directory I see the 4 files:
-rwxr-xr-x 1 plex plex   570 Jan  4 11:44 install.sh
-rwxr-xr-x 1 plex plex   457 Jan  4 11:44 lock.sh
-rwxr-xr-x 1 plex plex 56240 Jan  4 11:45 sqlite3
-rwxr-xr-x 1 plex plex   738 Jan  4 11:44 unlock.sh
At first, running ./sqlite3 resulted in:
-bash: ./sqlite3: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
I copied /bin/sqlite3 over top of it, reset permissions and restarted plex. No difference. I tried reinstalling the plugin, but this time I copied the “working” sqlite3 BEFORE running install.sh. It still doesn’t work.
Now, the kicker is, if I run “./lock.sh” and “./unlock.sh” manually I see the library disappear and reappear.
Any thoughts on how to fix?
Thanks!
When you first generated the plugin, there was a section about running a command if the plugin prompts that you do not have permission. Run this command and restart Plex. That will likely solve the issue. If you need the command again, simply make a fake plugin with the same name and skip to the end.
Turns out Lock for Plex needs the 32-bit sqlite3 executable. I replaced it and installed the i686 glibc libraries and it all started working!
Due to Github being acquired by Microsoft have moved to GitLab.
Hello, with Plex Plugins no longer working, is there anyway I can unlock my hidden directories one last time? I just need to unlock them so i can figure out what to do with them now.
On windows Version 1.16.5.1554.
