Looking for a simple text based way to log every finished
Hi all
i posted this a few months ago and got zero responses (thread was closes)…hopefully better luck now ;D
i am looking for a simple way (webhook?ssh?other) to simply log into a text file every TV series /Movie i finish watching.
i don’t really want to use an external service (such as trakt) so looking for a local solution. Im not vey technical so i am wondering if there are any examples the community can share that people have been using?
thanks a lot in advance
Z
Well, you could export the metadata from PMS using like:
The field you want is named “View Count”
Note though, that for episodes, I forgot to add it, so that’ll only be present when next release is launched
thx so much @dane22
this looks fantastic, installed it on my mac and it seems to work great!
a few questions
  1. any way to automate this (weekly, daily etc)?
  2. can one create 1 file/export with multiple media libraries (for movies, tv etc)
cool ill wait for the next release
thx so much for this epic add on!
best
Z
Automation is not possible, but who knows what the future might bring :wink:
(After all, it’s still in Beta)
Edit: [RFE] Automation · Issue #370 · WebTools-NG/WebTools-NG · GitHub
Nope, it’s Lib Centric
Also take a look at Tautulli. You could automate some stuff using scripts, I believe.
And adding to the export here…
If you create a Smart Playlist, that filters on “Unplayed is false” for movies, and one that filters on “Unplayed Episodes is false” for episodes, then you can export those playlists, resulting in a much faster export :wink:
thx @CostaHT !
that was what i initially thought of using, but couldn’t get the hang of it. Do you have any experience which Tautuli?
thx
thx @dane22 !
will try today
On Tautulli you can create a Notification type Script, and use a script to echo the movie name and any other detail of it to your text file.
This would be the trigger:
Screenshot from 2021-05-19 01-23-35
These are the parameters you’re looking for:
I don’t know why you need this, but if the idea is to be notified that someone has finished watching a movie, you can use their Notification Agents and send yourself notifications using e-mail, telegram, discord and many others.
thx @CostaHT !
i want to be able to log every movie/series i watch into a simple text file (Can be csv etc as well) so that i have a long term recored (im getting old and the memory cells aren’t as they used to be :laughing: ).
i hate using 3rd party closed apps (such as Trakt) so i though a simple text file that updates itself could be a good local solution. im very open to any other options if available :slight_smile:
I will look again into the Tautulli Notification Script, even though i tried that a few months ago an failed miserably (im not super technical :))
thx again, appreciate all your help guys!
Z
New version of WebTools-NG avail.
If you in global settings ask to subscribe to betas, you should be notified when relaunching
Otherwise, manually download and run it again
And contains the missing “view count” for episodes :wink:
thx @dane22!
