Main Preview/Info window not working after certfile fix
I suggest updating ATV firmware from 5.1 to 5.3. Two others with preplay screen issues have done this and fixed their problem. If you are worried about potential future jail breaking save your SSH blobs with Tinyumrbella before you upgrade.
Ok,
I will update the ATV and post the results.
Aaron
I updated the ATV3 to 5.3 as advised by institute11 and the PrePlayWindow now works.
Awesome ... thanks for the help everyone ... guess my reluctancy to update from all my previous jailbreaking experiences worked against me in this situtation.
Aaron
Good stuff. Baa, so there now appears to be a confirmed issue with the Plexconnect PrePlay screen and ATV firmware 5.1. That is three cases and all three solved by upgrading to 5.3.
Hm.
Interesting though, that nobody seems to be capable to provide a LOG (not a terminal COPY/PASTE) with loglevel High.
Without this, here is NO way to debug these things...
The Pem Cert was made on the same computer as the the ca cert - and like you said it is working up until the Pre-Play-Screen.  I tried creating a new folder in the library and then putting a movie file in their and still I get the same error - Trailers is not available. Try again later.  The movies are also playing fine on the ATV it is just that I can't get to the PrePlayWindow.
do you try movie that has full metadata by PMS analysis?
good to know solved
It's not solved - it's just hidden for now. Anyone trying to use 5.1 will stumble over it again...
