It Works - somewhat
Got plexConnect working right away. I can browse my tv Shows without problems. Now if try to watch an Episode i get an error that "Trailer is not available". This happens all Ways/Paths:
 TV-Shows > All Shows > show name > Series > File
 TV-Shows > Recently Viewed Shows > show name > Series > File
But if I go under "watched episodes" and select a previously watched one or via "On Deck" it Works just fine.
Any sugestions how to fix this are apreciated. Sandro
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software):
    ATV3, Firmware 5.1
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS):
    192.168.1.150
  • The device and operating system (including version number) that PlexConnect is installed on:
    MacMini, 10.8.3
  • The local IP address of the device that PlexConnect is installed on:
    192.168.1.150
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on:
    see above
  • The local IP address of the device that the Plex media server (PMS) is installed on:
    192.168.1.150
  • Where your media is stored (e.g. internal drive):
    internal
  • The PlexConnect version number.
    9.6.2013 9:00h Central Europe Timer
  • The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
  • Detail on the media file if it is an issue related to playing a media file
    Does not matter. AVI, MP4 and MKV same Issue
  • A log file (currently this is the output in your terminal/cmd window):
    DNSServer : ***forward request
    DNSServer : -> DNS response from higher level
    DNSServer : DNS request received!
    DNSServer : Source: ('192.168.1.109', 56271)
    DNSServer : Domain: trailers.apple.com
    DNSServer : ***intercept request
    DNSServer : -> DNS response: 192.168.1.150
    WebServer : serving application.js
    192.168.1.109 - - [09/Jun/2013 19:59:35] "GET /appletv/us/js/application.js HTTP/1.1" 200 -
    WebServer : serving /Users/sandro/Desktop/PlexConnect-XML_templates/assets/plexconnect.xml
    192.168.1.109 - - [09/Jun/2013 19:59:35] "GET /plexconnect.xml HTTP/1.1" 200 -
    DNSServer : Source: ('192.168.1.109', 64937)
    DNSServer : Domain: itunes.apple.com
    WebServer : serving .xml: /channels/all
    192.168.1.109 - - [09/Jun/2013 19:59:35] "GET /channels/all&PlexConnect=Channels HTTP/1.1" 200 -
    WebServer : serving /Users/sandro/Desktop/PlexConnect-XML_templates/assets/search.xml
    192.168.1.109 - - [09/Jun/2013 19:59:35] "GET /search.xml HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 19:59:35] "GET /&PlexConnect=Settings HTTP/1.1" 200 -
    WebServer : serving .xml: /library/sections
    192.168.1.109 - - [09/Jun/2013 19:59:35] "GET /library/sections HTTP/1.1" 200 -
    WebServer : serving  /Users/sandro/Desktop/PlexConnect-XML_templates/assets/settings.js
    192.168.1.109 - - [09/Jun/2013 19:59:36] "GET /settings.js HTTP/1.1" 200 -
    WebServer : serving .xml: /library/sections/2
    192.168.1.109 - - [09/Jun/2013 19:59:39] "GET /library/sections/2 HTTP/1.1" 200 -
    DNSServer : Source: ('192.168.1.109', 56668)
    DNSServer : Domain: p02-streams.icloud.com
    DNSServer : Source: ('192.168.1.109', 60581)
    DNSServer : Domain: p02-sharedstreams.icloud.com
    WebServer : serving .xml: /library/sections/2/onDeck
    192.168.1.109 - - [09/Jun/2013 19:59:45] "GET /library/sections/2/onDeck HTTP/1.1" 200 -
    WebServer : serving  /Users/sandro/Desktop/PlexConnect-XML_templates/assets/updateXML.js
    192.168.1.109 - - [09/Jun/2013 19:59:45] "GET /updateXML.js HTTP/1.1" 200 -
    DNSServer : Source: ('192.168.1.109', 62521)
    DNSServer : Domain: p02-content.icloud.com
    DNSServer : Source: ('192.168.1.109', 63512)
    DNSServer : Domain: msdub000024.blob.core.windows.net
    DNSServer : Source: ('192.168.1.109', 64913)
    DNSServer : Domain: configuration.apple.com
    DNSServer : Source: ('192.168.1.109', 59636)
    DNSServer : Domain: bookkeeper.itunes.apple.com
    DNSServer : Source: ('192.168.1.109', 49998)
    DNSServer : Domain: upp.itunes.apple.com
    DNSServer : Source: ('192.168.1.109', 58263)
    192.168.1.109 - - [09/Jun/2013 20:06:23] "GET /library/sections/2/onDeck HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:06:23] "GET /updateXML.js HTTP/1.1" 200 -
    DNSServer : Source: ('192.168.1.109', 59233)
    DNSServer : Domain: ax.init-cdn.itunes.apple.com.akadns.net
    DNSServer : Source: ('192.168.1.109', 64495)
    DNSServer : Domain: p2-buy.itunes.apple.com.akadns.net
    DNSServer : Source: ('192.168.1.109', 59410)
    DNSServer : Domain: mesu.apple.com
    DNSServer : Source: ('192.168.1.109', 61140)
    DNSServer : Domain: appldnld.apple.com
    DNSServer : Source: ('192.168.1.109', 61353)
    DNSServer : Domain: upp.itunes.apple.com.akadns.net
    DNSServer : Source: ('192.168.1.109', 51022)
    DNSServer : Domain: a97.gi3.akamai.net
    DNSServer : Source: ('192.168.1.109', 59138)
    DNSServer : Domain: a1271.gi3.akamai.net
    DNSServer : Source: ('192.168.1.109', 63388)
    DNSServer : Source: ('192.168.1.109', 57673)
    DNSServer : Source: ('192.168.1.109', 54169)
    DNSServer : Domain: itunes-cdn.apple.com.akadns.net
    DNSServer : Source: ('192.168.1.109', 60826)
    192.168.1.109 - - [09/Jun/2013 20:20:36] "GET /appletv/us/js/application.js HTTP/1.1" 200 -
    DNSServer : Source: ('192.168.1.109', 62053)
    192.168.1.109 - - [09/Jun/2013 20:20:37] "GET /plexconnect.xml HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:20:37] "GET /library/sections HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:20:37] "GET /search.xml HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:20:37] "GET /channels/all&PlexConnect=Channels HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:20:37] "GET /&PlexConnect=Settings HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:20:38] "GET /settings.js HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:20:44] "GET /library/sections/2 HTTP/1.1" 200 -
    DNSServer : Source: ('192.168.1.109', 58282)
    DNSServer : Domain: bookkeeper.itunes.apple.com.akadns.net
    DNSServer : Source: ('192.168.1.109', 56657)
    WebServer : serving .xml: /library/sections/2/unwatched
    192.168.1.109 - - [09/Jun/2013 20:23:09] "GET /library/sections/2/unwatched HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:23:10] "GET /updateXML.js HTTP/1.1" 200 -
    WebServer : serving  /Users/sandro/Desktop/PlexConnect-XML_templates/assets/scrobble.js
    192.168.1.109 - - [09/Jun/2013 20:23:10] "GET /scrobble.js HTTP/1.1" 200 -
    WebServer : serving .xml: /library/metadata/65135/children
    192.168.1.109 - - [09/Jun/2013 20:23:17] "GET /library/metadata/65135/children?unwatched=1 HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:23:17] "GET /updateXML.js HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:23:17] "GET /scrobble.js HTTP/1.1" 200 -
    WebServer : serving .xml: /library/metadata/65136/children
    192.168.1.109 - - [09/Jun/2013 20:23:19] "GET /library/metadata/65136/children?unwatched=1 HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:23:19] "GET /updateXML.js HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:23:19] "GET /scrobble.js HTTP/1.1" 200 -
    WebServer : serving .xml: /library/metadata/65137
    192.168.1.109 - - [09/Jun/2013 20:23:21] "GET /library/metadata/65137?unwatched=1&PlexConnect=EpisodePrePlay HTTP/1.1" 200 -
    DNSServer : Source: ('192.168.1.109', 61352)
    DNSServer : Domain: a771.da1.akamai.net
    DNSServer : Source: ('192.168.1.109', 62769)
    DNSServer : Domain: e673.g.akamaiedge.net
    DNSServer : Source: ('192.168.1.109', 56218)
    DNSServer : Domain: setup.icloud.com
    DNSServer : Source: ('192.168.1.109', 61617)
    DNSServer : Source: ('192.168.1.109', 60226)
    DNSServer : Domain: a2.mzstatic.com
    DNSServer : Source: ('192.168.1.109', 64701)
    DNSServer : Domain: a4.mzstatic.com
    DNSServer : Source: ('192.168.1.109', 56920)
    DNSServer : Domain: a3.mzstatic.com
    DNSServer : Source: ('192.168.1.109', 65246)
    DNSServer : Domain: a1.mzstatic.com
    DNSServer : Source: ('192.168.1.109', 62309)
    DNSServer : Domain: a5.mzstatic.com
    DNSServer : Source: ('192.168.1.109', 50157)
    DNSServer : Domain: se.itunes.apple.com
    DNSServer : Source: ('192.168.1.109', 59877)
    DNSServer : Domain: p02-sharedstreams.icloud.com.akadns.net
    DNSServer : Source: ('192.168.1.109', 50550)
    DNSServer : Domain: p02-streams.icloud.com.akadns.net
    192.168.1.109 - - [09/Jun/2013 20:23:42] "GET /appletv/us/js/application.js HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:23:42] "GET /plexconnect.xml HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:23:42] "GET /library/sections HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:23:42] "GET /&PlexConnect=Settings HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:23:43] "GET /channels/all&PlexConnect=Channels HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:23:43] "GET /search.xml HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:23:43] "GET /settings.js HTTP/1.1" 200 -
    192.168.1.109 - - [09/Jun/2013 20:23:46] "GET /library/sections/2 HTTP/1.1" 200 -
    DNSServer : Source: ('192.168.1.109', 58406)
    WebServer : serving *.jpg: /thumbnails/PlexConnectLogo.jpg
    192.168.1.109 - - [09/Jun/2013 20:25:40] "GET /thumbnails/PlexConnectLogo.jpg HTTP/1.1" 200 -
    DNSServer : Source: ('192.168.1.109', 53417)
    DNSServer : Source: ('192.168.1.109', 60634)
    DNSServer : Source: ('192.168.1.109', 58183)
    DNSServer : Domain: appldnld.apple.com.akadns.net
    DNSServer : Source: ('192.168.1.109', 60654)
    DNSServer : Source: ('192.168.1.109', 56461)
Try updating to the latest code, there was a bug that was fixed on Thursday relating to the pre-play screen.
Updatet to the latest code this morning, but still getting the same behavior.
Can you read the stick about how to reports a problem and fill out the template etc please, hopefully then we will be able to see what is going on.
Ok. Sorry I overread that part in the stick. Updated my first Post with the Informations
Can you update your PMS, you are running quite an old version.
Also please post the content of your ‘Settings.cfg’ file (if you do not have this file you are running an old version, please update).
f00b4r, is Settings.cfg can be found where your Settings.py resides? How come I don't have mine.
Yes but it is new in the last couple of days in the main branch.
It is generated the first run from your settings.py, from then on your config is read from settings.cfg (so this is where you should make any adjustments).
Is this bad that I don't have one?
It means you are running an older version, likely with some bugs in.
If it works for you then maybe wait a while for some of the big merges incoming.
Thanks, it works now.
I had PMS 9.7 but as a PlexPass Member I updated to 9.8 it solved the problems.
