Make the Play Next countdown timer user adjustable
Yes Please. Would be great if we can change this.
This cannot be introduced soon enough; there are ways floating online to do this that feel very hacky to have to do as an end user and should be a UI option we can set. End users should be able to change this setting to whatever number works for us (both for the classic and big picture views).
There are more if you look around enough but this should be up to the user and not arbitrarily per-decided. Should be a very easy addition for the Plex team to make. This is a very low hanging fruit improvement that would make users worldwide extremely happy
Yes please! Get this in ASAP. But does not seem like it will happen any time soon. Noone from Plex has replied here once…
Please allow this to be user configurable… my 2 year old wants it faster!
I commented on a different thread, but I’ll throw one here too.
Why wouldn’t this be adjustable?
I wish at the very least it would buffer the next episode while waiting the 15 seconds, as it is, its just wasted time.
This for sure should be an option or at least make it smaller then what the countdown is currently at like Netflix does. If not adjustable, maybe default it to like 4 or 5 seconds but I would like the option to change the timing .
It does not need to be adjusted. It needs to be removed. It is outdated, useless, and simply wastes time. Just play the next one please
I will just copy what I had in my post -
Since we have a skip credits button now, it would be nice to have a user setting that allows us to specify the 10-second countdown. Allows us to disable it so it runs straight through to the next episode / media. The skip credits button makes this more appealing for TV shows where we might just want to run straight into the next episode.
Yes it would be great if the Plex Apps (for me specifically Roku Channel Plex) would either:
  • Have this option in the TV/Roku app GUI would be great!
  • To satisfy everyone, if the apps loaded prefs from the server (if not available, use defaults)
    (If you go this route, please add to the PMS web interface so we dont have to edit files, and
    the adjustments will be persistent).
Cheers to the Devs
Plex is #1
This has been requested for years and no update…
Might just switch to Jellyfin, such a small issue taking this long to be solved is insane
PLEEEEASE, we need this.
This should actually now be available on a number of platforms.
See „ Auto Play Countdown Time (Plex Pass Required)“:
Yes yes yes, thank you!
