I investigate how metadata agent works to be able to update or create some new one.
The search function of my agent (not a primary agent) is called with theses items :
Searching for matches for {'guid': 'com.plexapp.agents.themoviedb://111111?lang=fr', 'force': True, 'primary_agent': 'com.plexapp.agents.themoviedb'}
In the API documentation, it is wrote that the media object have many properties including "filename"
In my case, this property does not exists :
Log ("media.filename : " + media.filename)
TypeError: cannot concatenate 'str' and 'NoneType' objects
I think the only properties I have available in my case are "guid", "force" and "primary_agent"
I want to get the full path to the media file.
How to do that ?
The Metadata Model Classes (from primary_metadata) does not give me access to the filename.
I tried with media.items[0].parts[0].file but it failed too.
When I set my metadata agent as a primary agent, the "filename" property is filled. But I want my agent to be able to work in both case (primary and not primary agent)
Thanks for your help.
