If you’re binge watching and enjoying the 15 second countdown screen between episodes.
The bug is at the start of countdown the menu swipes left on its own bringing up that ■■■■■ looking [no style] vertical menu and then locks you onto that menu so you can only scroll up and down.
Does it every time on countdown screen. If I try to quit the vertical menu it quits the countdown screen too.
Can I kill that menu off?
