I got 2 different oc (objectcontainer) from 2 functions. To display the content (mainmenu) I have to merge these 2 container.
Is there any easy way to merge them into one? Trying to iterate with them didn't work. Any hints?
Greets
Sascha
Greets
Sascha
Could you do something like
oca.items = oca.items.extend(ocb.items)
That will append one on to the other, assuming my syntax is correct that is
Sent from my HTC One using Tapatalk
Nope, does not work....
AttributeError: 'MediaContainer' object has no attribute 'items'
I would personally probably change up the way you are doing things, I've never had the need to merge multiple object containers for one menu item .. it sounds like you're doing something a bit funky there to be honest ...
It is possible if you do it like this:
def SomeFunction: oc = ObjectContainer()oc.extend(OtherFunction()) oc.extend(YetAnotherFunction()) return ocdef OtherFunction():
oc.add(…)
return ocdef YetAnotherFunction():
oc.add(…)
return oc
