metadata.sort_title for Agents
Are there any plans to add sort title support for metadata agents to the MetaData model - http://dev.plexapp.com/docs/agents/models.html ?
That would be really helpful to expand on the collections support to have them properly sorted.
I use sort titles in a good amount of my movies on XBMC, and not being able to import that is frustrating. especially since title_sort is a property in the cached info.xml
is there anywhere else this is modifiable? the UI has to save the data somewhere
