I was curious if it is possible to move the Plex AppData from the C: drive to another drive? I would like all of my metadata off of my SSD as it is running out of space.
Thanks in advance!
Thanks in advance!
You could use a symlink to move your appdata to another disk and plex wouldn’t know the difference.
A symlink basically redirects traffic to the right location transparently to most apps.
TBH you can probably even find a gui tool to make it for you rather than having to use the CLI.
Good luck.
Settings>general (show advanced)
The Path where local application data is stored to where ever you plan to move it to (do not include the “Plex Media Server” folder in path)This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
