I do not have a Channel directory any longer and can’t find any information on how to remedy this. I had one at one time as I have a couple of channels installed but can’t figure out what has happened to the feature.
Channel directory has been renamed Plug Ins
https://support.plex.tv/articles/200289536-plugins/
More: https://support.plex.tv/articles/?s=plug+ins&search=support_articles
Yes… I foolishly admit
My initial problem has to do with the addition of bundles to the Plug in folders. I have followed the directions from multiple sites and feel that the permissions for the files are the problem. The channels I have added manually all have the same problem of not showing up in the channel/plug in folder. I do have working channels that show permission of Plex as the group but no listed owner or others. The ones that do not work list me as the owner and group. I have changed the permissions on one of the none working ones (Plex as group) but it still doesn’t work I don’t know what the owner or other should be.
