Server Version#: 1.20.1.3252
Player Version#: 4.34.4
Since I’ve applied the PMS Update 1.19.3.2852-219a9974e all the MKV files added after that Update, can’t be played from Remote Web Player using Chrome, the following error is shown “Playback Error – Not enough CPU for conversion of this item.”
All the MKV files that were added prior to the mentioned update have no problem to be played, and neither all the MP4 added even after upgrade.
This issue also affects some TVs with old Player Versions, recent TV models (2018, 2019, 2020) are not affected.
For some reason there is a pattern of differences for these items in the database records.
Database: com.plexapp.plugins.library.db
Table: media_items
Field: color_trc
Value for media that plays without any issue: “” (Blank, not NULL)
Value for media that cannot be played: bt709
Table: media_streams
Field: extra_data
VIDEO:
ma%3AbitDepth=8&ma%3AchromaLocation=left&ma%3AchromaSubsampling=4%3A2%3A0&ma%3AcodedHeight=560&ma%3AcodedWidth=1280&ma%3AcolorPrimaries=bt709&ma%3AcolorRange=tv&ma%3AcolorSpace=bt709&ma%3AcolorTrc=bt709&ma%3AframeRate=23%2E976&ma%3AhasScalingMatrix=0&ma%3Aheight=546&ma%3Alevel=31&ma%3Aprofile=high&ma%3ArefFrames=6&ma%3ArequiredBandwidths=1798%2C1415%2C1155%2C1155%2C1155%2C1155%2C1155%2C1155&ma%3AscanType=progressive&ma%3Awidth=1280
AUDIO:
ma%3AaudioChannelLayout=stereo&ma%3Aprofile=lc&ma%3ArequiredBandwidths=129%2C129%2C129%2C129%2C129%2C129%2C129%2C129&ma%3AsamplingRate=48000&ma%3Atitle=Stereo
VIDEO:
ma%3AbitDepth=8&ma%3AchromaLocation=left&ma%3AchromaSubsampling=4%3A2%3A0&ma%3AcodedHeight=544&ma%3AcodedWidth=1280&ma%3AcolorPrimaries=bt709&ma%3AcolorRange=tv&ma%3AcolorSpace=bt709&ma%3AcolorTrc=bt709&ma%3AframeRate=23%2E976&ma%3AhasScalingMatrix=0&ma%3Aheight=536&ma%3Alevel=31&ma%3Aprofile=high&ma%3ArefFrames=6&ma%3AscanType=progressive&ma%3Awidth=1280
AUDIO:
ma%3AaudioChannelLayout=stereo&ma%3Aprofile=lc&ma%3AsamplingRate=48000&ma%3Atitle=Stereo
The difference for the video stream seems to be the lack this section:
requiredBandwidths=1798,1415,1155,1155,1155,1155,1155,1155
for the audio stream:
requiredBandwidths=129,129,129,129,129,129,129,129
I have tried to complete the information in the indicated fields of the database for the affected content, but without success, the same error occurs.
UPDATE media_items SET color_trc = '' WHERE id = 23040;
UPDATE media_streams SET extra_data = 'ma%3AbitDepth=8&ma%3AchromaLocation=left&ma%3AchromaSubsampling=4%3A2%3A0&ma%3AcodedHeight=544&ma%3AcodedWidth=1280&ma%3AcolorPrimaries=bt709&ma%3AcolorRange=tv&ma%3AcolorSpace=bt709&ma%3AcolorTrc=bt709&ma%3AframeRate=23%2E976&ma%3AhasScalingMatrix=0&ma%3Aheight=536&ma%3Alevel=31&ma%3Aprofile=high&ma%3ArefFrames=6&ma%3ArequiredBandwidths=1798%2C1415%2C1155%2C1155%2C1155%2C1155%2C1155%2C1155&ma%3AscanType=progressive&ma%3Awidth=1280' WHERE (media_item_id = 23040) AND (codec = 'h264');
UPDATE media_streams SET extra_data = 'ma%3AaudioChannelLayout=stereo&ma%3Aprofile=lc&ma%3ArequiredBandwidths=129%2C129%2C129%2C129%2C129%2C129%2C129%2C129&ma%3AsamplingRate=48000&ma%3Atitle=Stereo' WHERE (media_item_id = 23040) AND (codec = 'aac');
The issue persists till the 1.20.1.3252 version.
No specific error message is recorded in the logs.
When the Web Player runs in the same local network, there’s no issue.
