Mobile Sync 5.1 SS
when syncing to mobile device, the audio is always encoded to 2.0, even if set to sync original.
Would be good if this can be adjusted so it can sync with 5.1, which is better if casting.
2021 clean-up: obsolete (Mobile Sync is about to be replace by Downloads which handle this differently / allows original quality downloads if supported)
