When I search for Land of Bad, movie from 2024, it only shows that it is available to rent and it doesn’t show as being on Netflix. How does this get fixed?
- verify that you don’t use a VPN, because that could skew information about your location. Availabilities on streaming services are very much dependent on country, so if a wrong location is detected for you, you will see wrong availability information.
- Plex uses availability data from JustWatch.com
Ultimately, the issue has to be fixed by them.
