pretty sure this has already been explained as a windows limitation. something about windows services not having a display context, so not able to use gpu.
if you want windows gpu transcoding then you may need to look into creating a dedicated plex user and using auto-login functions to simulate running as a service.
@tamas 1.15.0.647 just popped up as an update in Plex for my DS718+ ⊠But the link doesnât work. I know the forum post hasnât been published yet for that build, but wanted to let you know.
When everything you see here in this Forum Preview thread becomes PlexPass, it will be fully available. At some point thereafter, when made Public available, they will also be forwarded to Synology to include in their Package Center distribution system.
Just tried installing this version (plexmediaserver_1.15.0.573-123756e9a_amd64.deb ) on my ubuntu server (Ubuntu 16.04.5 LTS), but it does not start.
journalctl -xe shows this error:
/usr/lib/plexmediaserver/Plex Media Server: error while loading shared libraries: libva.so.2: cannot open shared object file: No such file or directory
Check for the existence of /etc/systemd/system/plexmediaserver.service
If it exists, before deleting, verify the presence of /lib/systemd/system/plexmediaserver.service (where it belongs),
AND
cat /lib/systemd/system/plexmediaserver.service
Defines LD_LIBRARY_PATH to end reflect the new /lib subdirectory.
A migration error from when PMS moved to systemd was discovered. Weâve updated the installer to clean out the unwanted file in /etc but might not be in the build you have.
The new installer (most likely in the next build you see), will remove the file from /etc/systemd/system
This all came about because the initial releases of Ubuntu 16.04 placed them in /etc/systemd/system which was non-standard. Theyâve since complied with standard but, until now, the LD_LIBRARY_PATH hasnât changed so the error went undetected.
To avoid any confusion,
/etc/systemd/system/plexmediaserver.service.d/override.conf is the accepted standard and supported location to customize your Plex configuration.
1.15.0.573 is a little broken. Thatâs being fixed now. Please hang in a little bit.
1.15.0.647 was an OOOPS It wasnât supposed to be made live because not all the pieces are in place yet.
What I can tell you is that you will be seeing it SUPER soon. Weâ're making one last quick check through it and the download page to make sure everything is good.
I know everyone would love me to say âTomorrowâ but I canât say that with 100% certainty.
Weâre THAT close to full deployment.
Please just give us this last little bit to make sure everyone has a good first experience with the new builds and new features.
Supplemental: 1.15.0.573 is a manual download & update. Do not rely on the automatic
Yes, but you stopped responding months ago in that thread. Some people created a script to use the 1.15 transcoder on top of 1.14 stable. We would really like someone from Plex to reply In that thread (lots of people want to use other products that already supports it just because no one from plex replyâŠ)
