Multiple episodes, one file
@adamskoog said:
I’m going to guess that the original files had embedded metadata, you remuxing to mkv removed it and that is why it’s working and not an issue with m4v (mp4) containers.
In my case, I’m fairly certain it’s not the metadata, as I’ve not only tried this without using the local scanner, but actually gone so far as to rip the metadata out of the file completely using Atomicparsley. Further, my agents are set up such that local file names will override the internal metadata (I’ve had more than a few situations where thetvdb has episodes in a different order than they appeared on the original DVDs or in iTunes, for instance, and renaming the files overrides this just fine).
For whatever reason, the scanner handles MP4/M4V extensions differently for multi-episode files. It’s an odd inconsistency, although I’m not sure I care all that much in my case, since the way multi-episode files are handled seems a bit messy right now anyway.
What I’ve found works for me is to name multi-episode files as follows:
Show name/Season 01/Show name s01e01e02.mp4
Show name/Season 03/Show name s03e07e08.mkv
etc…
And more recently, I discovered that this works for files with 3+ episodes:
Show name/Season 01/Show name s01e01e03.mkv
(This displays all three episodes in Plex, for me)
I think that the “resume playback from hh:mm:ss” internal functionality could (and should) be extended to start such multi-episode files at their specified places, with the start time able to be specified in the episode’s Edit data. That would be cool.
@kappacrab said:
Hi there. I had the same problem.
When i used plex for the first time i had no clue how everything works. I didnt even use a guide to get to know and set everything up. For some reason i figured it out myself, even the naming scheme, where the little tool called “RenameMaster” came in very handy.
So for this particular problem in this thread i also tried to use a “-” to add another episode number for a single file. It didnt work for some reason, now i used a “+” instead, e.g. “[name of series] - S01E001+002”. Now plex seems to split both and shows the exact amount of episodes.
Visiting the single episode overview it still shows the doubled length on both episodes. I didnt try out watching them to see how seemless they play or if it will be played two times in a row.
I hope someone can make use of my findings.
EDIT: Works seemlessly.
I’ve been reading all kinds of posts and trying different naming schemes, but this one did it for me! Using + as described above made Plex correctly combine the episodes.
I’ve not had an issue with having TV in the following format:
Series Name\Season XX\Series Name - sXXe01-e05.mkv
Mostly I’m commenting because I can’t access the feature request (https://forums.plex.tv/topic/129456-feature-request-watched-state-for-single-filemultiple-episodes/) posted by adamskoog and I want to make some noise for that.
Since there’s no indication which episodes reside in which file aside from what starts playing when you select it, it’s really difficult to find an episode in a season that’s stretched across several files. Want to watch episode 14? If you can’t recall where it exists in relation to the files you have, you can only start playback and fast forward to try and find the episode.
Even more frustrating is if you watch all episodes in a file, say 1-5… Plex only shows that episode 1 has been watched! You could come back later, wanting to continue on, and have no idea where you were. If you accidentally select 5 again, you need to fast forward all the way through the file only to find out, “Hey, this looks familiar…”
This is still a thing. Just added a series where all the files are double episodes and are MP4 files with names like “Show Name - 1x01x02 - Episode Title.mp4”, and Plex only adds it as a single episode (the first one listed in the file name, in the example just Episode 1). I’ve been using this naming format for years with no issues, that I’ve noticed, but suddenly with this new series I added half the episodes were missing! After much trial and error, Plex Dancing, etc, I figured out that all I have to do is change the extension from .mp4 to .mkv and it magically figures out they are double episodes and assigns them as it should (to both Episode 1 & 2 for example above). If I change it back to .mp4, then it thinks it is a single episode again and trashes the latter one. Frustrating!
My choices seem to be:
  1. Leave as is and accept I’ll only see odd numbered episodes in Plex for that series.
  2. Split all of them into the individual episodes and name accordingly.
  3. Remux/convert all of them into mkv containers.
But really seems like the real option would be #4 - Plex fixes this issue and makes it act consistently after this has been a known issue in these boards for years!
This method worked for me (with Seinfeld, several two part episodes combined into single m4v files). I used + between episode numbers in the single file name and Plex correctly parsed and separated the episodes in the guide.
Example:
E:\PLEX2\TV Shows]Seinfeld\Season 05\Seinfeld - s05e18+19.m4v
shows correctly in Plex as two episodes like this:
The Raincoats (1)
Episode 18
and
The Raincoats (2)
Episode 19
Having the same problem here with Hinterland. I have tried:
  • Hinterland - s01e01-e02
  • Hinterland - s01e01+e02
  • Hinterland - s01e01-02
  • Hinterland - s01e01+02
…nothing seems to work. Mine are .mp4 files.
  1. Make certain Local Media Assets is not the top-listed Agent prevents reading metdata from MP4 files and overruling what is discovered on the internet DB. (most important with MP4 files)
    2 Naming
-rw-r--r-- 1 chuck chuck 7043886718 May 27 13:47 Star Trek The Next Generation - S07E25-E26 - All Good Things....mkv
Hi - no, It’s 4th (The TVDB is first).
Did you take your media to the Plex Dance after renaming it? :smiley:
:smile:
Thanks for the reminder - but It’s still the same.
I’ve just checked another show which is doing the same thing (and I could have sworn it was correct in the past).
Another naming format accepted: Name - S01E01E02E03 - optional title.ext
thanks. but that made no difference either.
Are they MP4 or AVI ?
If so, you must get the embedded Title & Name fields erased. Whatever is in there is overriding how you’re naming it.
That’s the only thing which will cause it Unless you didn’t do the “Plex Dance” when renaming.
Dance =
  1. move files out
  2. Scan files
  3. Empty Trash
  4. Clean Bundles
    – Now they have been removed
  5. Rename however they are supposed to be.
  6. Move back
  7. Scan files and let match
You do this because PMS keeps the file’s checksum. Once matched incorrectly, the checksum is re-used along with the old info until completely purged.
[/tmp] # ls -laR Hinterland
Hinterland:
total 0
drwxr-xr-x  3 chuck chuck            60 2018-08-19 02:42 ./
drwxrwxrwx 20 admin administrators 3160 2018-08-19 02:53 ../
drwxr-xr-x  2 chuck chuck            60 2018-08-19 02:50 Season 1/
Hinterland/Season 1:
total 4
drwxr-xr-x 2 chuck chuck 60 2018-08-19 02:50 ./
drwxr-xr-x 3 chuck chuck 60 2018-08-19 02:42 ../
-rw-r--r-- 1 chuck chuck 97 2018-08-19 02:42 Hinterland.S01E01-E03.mkv
[/tmp] #
17
@ChuckPa - where are you based? …trying to work out if this is v late or v early for you! :wink:
I am Eastern coast US based (in my profile)
If you use MKVtoolnix-GUI to open any of these files, does it pre-populate any of the descriptive fields with series / episode names? These will show in the Output tab
Hi - my files are .mp4 so it won’t open in MKVtoolnix.
However, in Metz it showed the following:
42
