Music library problems
I don’t know if PlexConnect is working as intended, or if the following situations are bugs, can you please clarify ?
  1. If I select “All Artists” in the top level menu I get an almost all black screen, with an horizontal line in the middle, and a “More” box that, when selected, give me the available albuns. It would be nicer to have a single screen, if possible
  2. If I select “By Genre” in the top level menu I get an almost all black screen, identical to situation 1. above, but this time the “More” button is not able to find any album
  3. If I select “By Decade” or “By Year” in the top level menu I get a list of available decades/years, but from then on I get no album list at all
  4. If I select “More…” I get the “Accessing Trailers” message with a never ending rotating circle. If I press “Menu” I return to the previous screen
Sounds like a bug to me… Music or Premium Music section?
Did you update your PMS recently? I currently tent to blame that one for changing interface XMLs…
Thanks baa,
Music section (not premium)
I’ve tested with PMS 0.9.12.19 and 0.9.14.4
In the PMS log I have this error message -> ERROR - Error resizing an image, we don’t trust what we cached [/volume1/Plex/Library/Application Support/Plex Media Server/Cache/PhotoTranscoder/9c/9cca471bda559007dce37a7fd1922551326f1036.jpg]
Dec 01, 2015 08:34:27
Well, open that image if it is familar. Or delete it to have PMS rebuild it from scratch?
Further tests seem to indicate that situation 1) is apparently caused by a malfunctioning PIL. I’ve updated PIL sometime ago, and now I notice that I do not have fanart anywhere (films, tv shows, etc), even though PlexConnect says that PIL support is Ok… I’ve requested the previous version to Synology to confirm (I’m using Python Module 0008, and I’m almost sure that with 0006 fanart was Ok).
Situations 2) 3) and 4) seem to have nothing to do with the error that appears in the PMS log. That PMS error also appears in a number of other situations, and they seem to work. Do you need more info to investigate what may be causing these errors ?
A log (“High”) might be helpful… try to keep it small, just diving into “All Artists” for a start. :smiley:
Here are the logs for All Artists. With fanart:
  • On - When I select an artist, the next screen has the top half black, a blank horizontal line, and below the line a thumnail and the more… button that, when clicked, shows the second screen, where I see the thumbnails of the various albuns
  • Off - When I select an artist, the next screen has a large thumbnail (the same image that appears when fanart is on, but larger), no blank line, and the more… button that, when clicked, shows the second screen, where I see the thumbnails of the various albuns
I see nothing wrong here, except for no fanarts appearing, but I don’t know if they are supposed to appear when fanart is active. In my opinion the two screens could be combined in a single one, that would make navigation easier.
Edit - I have several multi-CD albums. In PlexWeb I see this
Disk 1
|- Track1
|- Track2
Disk 2
|-Track1
|-Track2
In PlexConnect I see this:
|- Track1
|- Track2
|-Track1
|-Track2
Therefor, with PlexConnect, I loose the info of CD1/2/etc.
Okay, I checked the music section. I think it works as designed -
“Artists” will actually give you information about the artist (yeah!). Maybe a “Play” button to directly play something form that artist might make sense. Rolling down/“more” gives you a list with tracks or videos, depending what you got.
With fanart on the screen shouldn’t be black, though. As far as I see it should give you a nice background picture of the selected thing… could you check if there is anything to further update your PMS library in this regards?
Not sure what’s going on with the missing CDs…
Sorry for not replying earlier, but I’m struggling to fix my fanart problem (fanart is no longer working for me, films, series, etc., but that’s another problem, for another thread).
With fanart active I do not see the “more” button, I can roll down to the next screen, but his is not very “intuitive”. With fanart disabled I see the “more” button. What happens in your case ? Do you see “more” button when fanart is active ?
About multi-CD support, here is what I see in PlexWeb
In PlexConnect I do not have a “Disk 2” line separating track 21 of the 1st CD and track 2 of the 2nd CD. As in this case the music album has 5 CD’s, when I scroll to the bottom it’s not easy (in PlexConnect) to know if I’m on CD 3, 4 or 5.
multiple discs…
how are they ordered on your hard drive? Each one in a distinct folder? With disc number as additional ID to the track?
Case 1 - Separate folders
Case 2 - Single folder, manual update in PlexWeb to indicate which tracks are in disc2
Case 3 - Single folder
moody_blue:
And with all “cases” you have the issue that PlexConnect doesn’t differentiate between the CDs? I double-checked, only case 1 (separate folders) and it seems to work fine.
FanArt on/off should give you the following views:
And both link to the albums view - in this case one collection of 3 CDs:
At least in no-FanArt mode, the Albums could live in a shelf on the bottom of the artists’ page, yes.
Thank you very much. Your information was very valuable to guide me on how to debug the situation. I had a general problem with fanarts, they did not show up anywhere, even in films, so I made a Refresh All in PMS, library by library, until I had fanarts in all libraries again.
Then I’ve gone to PlexConnect to show fanarts of a specific artist (Eric Clapton) and they do not show up. This specific fanart shows up in Plex for android in my phone. I do not see anything strange in PMS logs, but PlexConnect logs contain an error. I’m attaching the relevant info.
Also I do not see multi-CD albums separated with identical thumbnails, as you have in Bruce Springsteen. I have a single thumbnail (both in PlexWeb and PlexConnect), therefore I can play the whole album, with all its CD’s. In PlexWeb (and also in Plex for Android), when I open this single thumbnail, I see a list of all tracks, but the tracks of CD1 have “Disc 1” top label, the tracks of CD2 have “Disc 2”, and so on. This is what I would like to have also in PlexConnect.
Edit - If you want, you can use PlexWeb to give the same name to your Bruce Springsteen CD’s and they will appear under the same thumbnail
Those 3 CDs were held in separate folders. Not sure, if this influences the way PMS grabs and orders them?
I will see to do some tests with different naming configurations as you suggested.
