Hello and thanks in advance for help!
I have been a plex user for some time with movies, shows and music. I do not really use it much for music, but it is there.
I have a friend who has a gigantic music collection that I am migrating to Plex for him. We are talking 1TB+ from multiple external drives and PCs.
Currently I have de-duplicated, used some tools to make sure tagging is correct, etc. I now have what I think is a good set of his music collection at < than 1TB.
When it comes to organizing, Plex sorts based off of tags, then if tags are incomplete, folder name which as I understand should be in the format of Artist_Name - Album_Name
This is okay for a good portion if the music. For example in Plex you would look for Led Zeppelin and see each album inside.
However, a large portion of this collection is DJ mix sets and other 'Various artist' albums. This causes those albums to not to sort together. For example, each track of a Paul Oakenfold album is by a different artist, and by the folder structure above, is in a different folder.
Will plex understand if I just use Album Name as a folder, instead of having artist as well? Is there another solution I am missing? I am using Picard and MediaMonkey to retag and sort, but unfortunately not all tagging is consistent, as some have Album Artist correct, and the song tagged with Contrib artist, others are the reverse.
Any input or links are much appreciated.
