my apple tv 3 does not work with plexconnect
hi
can you please help me?
sorry for my bad english
00:05:57 PlexConnect: ***
00:05:57 PlexConnect: PlexConnect
00:05:57 PlexConnect: Press CTRL-C to shut down.
00:05:57 PlexConnect: started: 00:05:57
00:05:57 PlexConnect: IP_self: 192.168.0.14
00:05:580 0:05:58D NSServer: started: 00:05:58W
ebServer: started: 00:05:580
0:05:5800:05:58 DNSServer: ***
 W00:05:58 ebServer: started: 00:05:58DNSServer: DNSServer: Serving DNS on 192.1
68.0.14 port 53.
00:05:58 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.
168.0.14
00:05:58 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
.apple.com.edgesuite.net'] => 127.0.0.1
00:05:58 DNSServer: forward other to higher level DNS: 8.8.8.8
000:05:58 WebServer: ***0:05:58 WebServer: ***
00:05:58 WebServer: WebServer: Serving HTTPS on 192.168.0.14 port 443.0
0:05:58 WebServer: WebServer: Serving HTTP on 192.168.0.14 port 80.
00:05:58 W0ebServer: ***0:05:58
 WebServer: ***
00:06:07 DNSServer: DNS request received!
00:06:07 DNSServer: Source: ('192.168.0.13', 51889)
00:06:07 DNSServer: Domain: p39-buy.itunes.apple.com.akadns.net
00:06:07 DNSServer: ***forward request
00:06:08 DNSServer: -> DNS response from higher level
00:06:08 DNSServer: DNS request received!
00:06:08 DNSServer: Source: ('192.168.0.13', 64729)
00:06:08 DNSServer: Domain: p39-buy.itunes.apple.com.akadns.net
00:06:08 DNSServer: ***forward request
00:06:08 DNSServer: Source: ('192.168.0.13', 51889)
00:06:09 DNSServer: -> DNS response from higher level
00:06:09 DNSServer: DNS request received!
00:06:09 DNSServer: Source: ('192.168.0.13', 51983)
00:06:09 DNSServer: Domain: trailers.apple.com
00:06:09 DNSServer: ***intercept request
00:06:09 DNSServer: -> DNS response: 192.168.0.14
00:06:09 DNSServer: Source: ('192.168.0.13', 51930)
my settings
[PlexConnect]
enable_webserver_ssl = True
logpath = .
enable_dnsserver = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = C:/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
ip_pms = 192.168.178.10
enable_plexgdm = True
port_ssl = 443
Nevermind
hm?
Probably the fastest way to get it work would be to rename your plexconnect to something else. Redownload the latest version of plexconnect. Run plexconnect.py one time to generate a default settings quit plexconnect and start it again. Dont edit anything or change any settings on any of the files whatsoever. Put the trailers.pem where it needs to be and point your atv dns to your device running plexconnect and post results. I assume you have already loaded trailers.pem on to your atv. What is hosting plexconnect by the way. Use the links to troubleshoot.
https://github.com/iBaa/PlexConnect
https://github.com/iBaa/PlexConnect/wiki
