@dragonmel said:
@Guinea
i can appreciate your predicament
I had my previous plex build running for many many years on a hackintosh build on a e8400… it had 8 drives running zfs and it was getting very long in the tooth and before a motherboard failure or mass drive dyoffs… as my drives had over 50,000 hours on them… I decided to do something new and build an esxi all in one with ZFS serving the datastores for Esxi interally vs using a filer via nfs/iscsi… so week and weeks of reading and learning esxi, linux (plex new host os) etc etc… finding the hardware I wanted … dual l5640 CPUs are almost perfect… low power… 24 threads and each thread is capable of dealing with the dreaded VC1 codec… but without mainstream h265 and 4k standards, clients etc… future proof is a questionmark… bottom line is even if I could fly out there tomorrow and drop a complete setup in your lap… it would probably be down in days… and since you didnt do it for yourself you would not have learned to walk the path and probably couldnt fix it easily…
my ‘suggestion’ and I really mean this poliltely is to repurporse an old PC for now or buy some POS on craiglsist as a learner / junker… your dad didnt teach you to drive in his porsche right…? and play with the plex server and some clients… play with some pre canned all in one setups… play with zfs …that will do much of the setup and heavy lifting… get an idea of what works… how it works… and how to admin it… then when you have an idea how all this works… go dump the coin to make it happen… personally if I were in your technical shoes… I would look really hard at Freenas… specifically 11.1 when it comes out in a couple of weeks… 11 is almost a beta although the latest 9 is really stable just lacks some new features and prettier web pages of the new 11. Freenas has a huge community… many use it as a all in one plex box so you will get excellent advice… and it puts a pretty good wrapper around zfs which is in most implementations a command line file system… its not hard to learn but its mostly commandline… freenas while dumbing it down will mostly keep you safe… and jails, plugins, and now docker I believe you can run almost your entire house IT requirements … plex, file sharing, nextcloud, home automation… etc etc all in the freenas web based environment.
getting a specific answer to a specific question is usually pretty easy around here… but your inital post is well… like going into the buddist temple of the Lama and asking for the meaning of your life… its going to be long, convoluted and may not get to the point of what you actaully want… only you can answer that…
there really is no shortcut here. you have to be able to install and admin all the pieces or you will have a broken setup in notime…
if you REALLY wanted to multipurpose… when plex first came out it wasnt a backend frontend it just ran everyting on a pc… and so you had to have the TV hooked to that box… and it was GREAT…
if you are building a media center / theater into the house and have an equipment closet behind it or decide you can build you freenas box whatever quiet enough to be in your theater rack… hooking it into your tv and runing a openpht or PMP client on the same machine as the server might have its bennifits… direct to the biggest TV for 4k without network latency, and a decent GPU that can also help perhaps your plex server with hardware support when it comes out… just a thougth…
I appreciate the detailed answers. The problem I have is that I am long winded and my ideas are always so picture-perfect in my head. Getting them down on paper so they make sense and then asking the right questions has always been my downfall. I guess what I really want for me to get started is a link to a build thread that is recent (not something from years ago), using new hardware, FreeNAS, ZFS, all the bells and whistles that you mentioned. I know there is no perfect rendition for what I am looking for, but if I had a foundation of say “Buy X, Y, Z to get started and do this” then I think I would have a better understanding of it all by cherry picking the pieces and asking about them more directly.
As an example, if I had a build to follow, I could post on here about the actual CPU he/she used and see if a better option was available for what I want to do. I know it is kind of hard to find something like that, but I definitely learn better that way. Especially considering how all of these concepts and technologies are new to me. I would feel better if I had something at least CLOSE to what I wanted to accomplish, and could just use a better CPU than he/she did to get better performance out of it.
