So my birthday gift cards have shown up and I have decided that for my birthday I am going to start working on a proper network… I have a nice router and all the needed extenders and whatnot so I don’t need to worry about that…
Instead I want to say goodbye to hooking my external hard drives into my router… 90% of the time they work great but 10% of the time they drive me absolutely insane.
So that is where I keep my movies and network storage, its scary since all I use are 2 external hard drives I have no data backup, least not the typical kind… I do have like 50 blurays I keep of backups for my ripped/shrunk movies so if any of those hard drives suffer irreparable damage I can salvage them.
I run plex on an few year old laptop and overall I have no complaints there save that sometimes it seems to have issues seeing some of my tv shows that are on one of my hard drives… but I blame that more on the hard drive than the computer or plex.
Now for the question… while I wont have enough money to do everything I want right away and will probably need to live with the current setup awhile longer I can at least get a proper start.
What would you guys recommend, a NAS drive then have my computer run plex similar to what I do now or would it be better to get a computer with enough internal memory to just do it all at once.
My eventual plan is definitely to replace that laptop no matter which way I choose, I want to have a computer that can run plex as well as have a few tv tuners in there so I can tivo a show, then if possible I would then have that file ready for viewing throughout the network.
I had originally planned on getting a large computer case that has space for a lot of hard drives that also preferably has 2 network jacks so I can hook it into the network, as well as link a NAS drive to it directly or even give that computer to links into the network doubling its bandwidth.
Anyway I digress… in your experience which is the best solution, NAS drive to have the storage or internal drives? either way I want it expandable to a bunch of storage, I don’t like some of the nas drives I see with room for only 2 drives.
Thanks for any advice you can provide… I should have enough money for a case and possibly the motherboard, or I dont know on NAS setups since I dont know which brands are reliable so I would need some research first before I decided what I should buy or if I can afford it at this time.
